Forum: Beta Builds Regression Bugs
Topic: BUILD 2139 - Page: 2
I'm using the Fruit skin BTW
It appears that visibility may not be implemented for dropzone. Skiners could possibly edit the mentioned skins (and nest dropzones into panels) , but i believe the Team will provide a fix for this soon.
Issue reported. Next please ;)
Thanks Bob!
security works fine here with 2139
Working for me too, win8.1, fruits skin.
Strangely, security has started working again. How weird!
I thought I posted that contentunlimited did not work last night. Was it removed, leveled up, or did I forget to save?
EDIT Working now, on both machines.
Not sure where the post went Rick, but the team are aware.
Actually CU should work - its Netsearach (purple icons) that have the issue.
Should be fixed soon.
@ Rick
I had that as well with CU, now it's working fine again.
I think that sometimes when a lot of changes are brought into a system "never change a working system" it takes a while until everything geta sorted out again, I'm not an expert but I've noticed this several times.
Working fine now, but I was trying to show off last night with a user of another software. Had two DJs in the booth, one was a VDJ user that knew nothing about 8, and the other used our competitors. Told the guy to give me a song, and I could get it. Well, that did not turn out so well, and it was not even a hard song. That's life. As long as it was not a customer, with a hundred dollar bill in his hand.
I just noticed that when you loading track to decks it taking too long sometimes it's not quick like 2126
