Forum: Old versions
Topic: VDJ8 "PLUS" Controller (Numark N4) Computer System requirements
Hello,
I am looking at purchasing VDJ8 "PLUS" Controller (Numark N4). I am a bit concerned about the system requirements for Virtual DJ and the machine I will be using it on.
My system specs are as follows:
OS: Windows Vista Basic 32 bit
Processor: AMD Athlon 64 X2 6400+ dual core 3.2 GHz
RAM: 4 Gb
Video: GTX 550 Ti 1Gb DDR5
Are the above specs sufficient for audio mixing using VDJ8 "PLUS" Controller (Numark N4)?
Thanks for any input.
Posted Mon 19 Jan 15 @ 11:39 am
UPDATE: Works perfectly! Thanks, Atomix for making some great software that works well even on older AMD machines running Vista.
An upgrade to Windows 7 wouldn't go amiss though. Vista is a poor relation.
