Forum: Old versions
Topic: Do not see RMX2 when switching to sound card
I recently purchase the Hercules DJ RMX2 and i am having problems getting Virtual DJ 7.4.2 to recognize the sound card. Everything works on the RMX2 however, when i go to config/sound setup/sound card the RMX2 does not show up, but all the buttons work. I have downloaded all the drivers and updates from Hercules and Virtual DJ. My Hercules MK2 and RMX show up and work just fine. What can i do to fix this?
Posted Thu 15 Jan 15 @ 8:25 pm
You mean its not showing as ASIO ? It does if you select 4.1 in Outputs ?
I have the same problem ... did u find a solution ??
You could try to uninstall older versions of Hercules Drivers and have a clean installation of the new ones.
