1. tags are not read correctly on another pc from exactly the same files! (at least not all) and yes I hit batch reload all tags. This is a very annoying problem, since I have several DJ systems and want to use the rating stars etc. Please look at it, this is quite a big deal
2. sampler output has te be set every time: please make it remember
3. TOUCHSCREEN issue: rightclicking sometimes gives this annoying options screen and it doesnt go away. sometimes you have several of these screens, blocking stuff.
![](/image/85499/153893/folder touchscreen window issue 2.jpg)
Posted Fri 02 Jan 15 @ 10:08 am
2 could be sorted with a Onint mapping, until a fix happens.
deck X sampler_output
Posted Sat 03 Jan 15 @ 3:41 pm
good info loco thanks!
Posted Sun 04 Jan 15 @ 6:29 am
You could also probably set up a sampler output in the audio config, set it to the channel you want, then save the config.
Posted Sun 04 Jan 15 @ 6:38 am
hmm ok thanks groovin!
Posted Mon 05 Jan 15 @ 6:35 am
does the touchscreen issue also happen with using the mouse?
are you using 2nd monitor video out?
On a PC?
if yes to these, then look in the virtualdj shortcut on your desktop and disable desktop composition.
(This WILL turn off the modern looking desktop features but only during your virtualdj session..)
On a PC?
Posted Mon 05 Jan 15 @ 2:34 pm
OK cool will try thanks!
Posted Fri 09 Jan 15 @ 8:59 am
