Hi,
I notice that when a loop is enabled in VDJ8, that the waveform window displays a shadow on the colour of the deck for the duration of the loop.
Is there any way of disabling this shadow?
Thanks in advance.
Thanks in advance.
Posted Fri 26 Dec 14 @ 3:02 pm
No, it's there to give you a visual indication of how long the loop is.
Why do you want to disable it?
Posted Fri 26 Dec 14 @ 3:04 pm
Hi Kradcliffe,
Thanks for getting back to me.
The way I like to DJ is have the track that is coming up looped, so I'm always mixing the beginning of the new track when it is playing in a loop.
With the shadow showing on the waveform, it makes the actual waveforms of both decks less clear and more difficult to line up.
That's the only reason that I'd like to disable the shadow.
Thanks.
Thanks.
Posted Fri 26 Dec 14 @ 3:25 pm
If you download the VDJ8 by Fruit skin there are loads of options for the waveform displays. I use the traditional red/blue and the loop shadow doesn't bother me.
Keith
Keith
Posted Fri 26 Dec 14 @ 3:31 pm
Hi Keith,
Thanks for that.
Is it the skin that's on these pages?
http://www.virtualdj.com/forums/190684/VirtualDJ_Skins/_NEW___VDJ8__VirtualDJ_8_but_by_FRUiT.html?page=1
http://www.virtualdj.com/plugins/index.html?search=fruit
I've just downloaded it and will give it a try.
Thanks again,
Richard.
Thanks for that.
Thanks again,
Richard.
Posted Fri 26 Dec 14 @ 4:06 pm
