Forum: Old versions
Topic: Virtual DJ 7.4 PRO problem
Hi!
I have a problem! I bought Reloop Beatmix. I setup ASIO drive and setup Virtual DJ LE Beatmix Edition. But I already have Virtual DJ 7.4 PRO so I uninstall Beatmix Edition. Then I open VDJ PRO and it says "Cannot find the skin in Virtual DJ Document or Libary. Please reinstall"
but I can't reinstall because playlists will lost. Pls help.
Thank you.
Posted Tue 23 Dec 14 @ 11:16 am
You could rename any existing skin to exactly the name of the default LE skin.
Or, if you don't know that,
Reinstall LE
Launch PRO
Get a skin from the skin page a select it in PRO
Re-uninstall LE
