I Have The Mixtrack 2 I Have Virtual dj le and when I open it it says ''error in the sound driver  your sound driver is probably not connected or the settings are incorrect'' then I press ok and when it opens up I  cant play any songs  I tried uninstalling and installing that does not work I tried restarting my computer tat doesn't work plz help me.
    Posted Sun 21 Dec 14 @ 1:51 pm
          Have you checked the Config/Settings to ensure the correct soundcard set up in Virtual DJ?
You could also check to make sure the device drivers are installed on your computer.
Posted Thu 01 Jan 15 @ 2:31 pm
          Thx danny i fixed it
    Posted Thu 01 Jan 15 @ 2:37 pm
