Hi everyone, just want to share a thought with you.
There are no mappers for hercules dj 4 set in vdj8 and for other hercules console.
But there are some mappers for the other controller, that are native with traktor.
don't you think this is not fair?
So ,someone would post a mappers for the hercules4set?
Anyone is able to?
Anyone is able to?
Posted Sun 09 Nov 14 @ 5:25 am
In the wiki under supported controllers, I see quite a few Hercules listed.
https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
Posted Sun 09 Nov 14 @ 2:09 pm
Yeah but no one for the dj4set as some other hercules controller.
However i m going to make it manually, helped by an Italian user...
Posted Mon 10 Nov 14 @ 2:08 am
of course the DJ4Set is natively supported ;-)
Posted Mon 10 Nov 14 @ 2:13 am
Yah i know man! But i mean ... no mappers for the controllerist licence... it's not fair! We can't download any mappers!
Posted Tue 11 Nov 14 @ 5:23 am
I have a Hercules DJ 4 Set and a licence to download the Virtual DJLE7 Dj4 software and have also taken the 20 day upgrade. The Virtual DJ does not seem to work with the controller, or at least it does not look like the Hercules DJ4 Set. As the Hercules came boxed with this DJ software I thought that it would work with it straight away. There is no option to set the DJ4 Set as the default controller in settings either. It only seems to be mouse controlled, which rather defeats the object of buying a hardware device!!
Any help appreciated.
Posted Wed 22 Apr 15 @ 10:40 pm
did you install the latest Hercules Control Panel ?
http://ts.hercules.com/eng/index.php
Posted Thu 23 Apr 15 @ 1:23 am
