Forum: Old versions
Topic: Headphone cue problem
I recently updated my VDJ computer from XP to Windows 7. Ever since, I've been having an issue with the headphone cue feature.
I have a Delta 10 card installed in the computer, and have VDJ set for Advanced Audio, as follows:
Deck 1: Channels 1&2
Deck 2: Channels 3&4
Headphones: Channels 5&6
The headphone channel is always getting audio from whatever deck is playing, as well as what I cue up on the headphones.
Tommy
Posted Fri 17 Oct 14 @ 8:09 pm
Why do you have Deck 1, deck 2 in your Audio Setup ? Are you using an external analogue mixer ? If you do m the the Prelistening should be handled from your external mixer and not the software.
If you dont use an analogue dj mixer then have Master and Headphones only, in the Audio Setup.
Posted Sat 18 Oct 14 @ 4:50 am
