Topic: Virtual DJ 8 BPM Engine
There have been a few occasions thus far where I noticed the BPM engine for VDJ 8 return a value for a track that was considerably off from the actual BPM value. The track itself did not contain any BPM variations. The actual BPM and the returned BPM were also not multiples of each other, so this is not similar to those cases where a 150 BPM track is detected as a 75 BPM track. Below is a specific example.
Example:
-Track was detected at 166.67 BPM
-Actual BPM of track was 124.99 BPM. This was also confirmed by VDJ 7
-Using the 'Re-Analyze BPM' option did not help
Posted Sun 12 Oct 14 @ 12:50 pm
What's the track?
Also what format is it in? That's had a bearing on things in the past.
Appreciate the response guys. The track is in an MP3 format. The track itself was by remixed by a local DJ, so I'd have to circle back with him first before I can actually send over for analysis. That said, have you experienced this behavior at all? If so, anything you can shed besides VDJ 8 perhaps using a different BPM engine than VDJ 7 that would explain this behavior? Are there any ways to tweak the BPM engine in VDJ 8?
There are no tweaks, I run into this problem from time to time but I play breakcore which can be very chaotic so I sort of accept it.
Does it have just a straightforward 4/4 beat, or some sort of hoppy skippy rhythm?
The latter do tend to confuse software.
