I'm vrey new at useing VDJ8. I have been trying to map my keyboard to play samples. For Example. " Q " - Play sample 1, " W " - Play sample 2. When oi go through the Configure screen, I can only get Sample 4 to play. Maybe this is the default setting. I must be missing something simple. Is there a video tutorial for VDJ8 on this topic? If not, can somebody please walk me through the process.
Thanks,
Thought
Thanks,
Thought
Posted Tue 23 Sep 14 @ 1:24 pm
Hello, this is simple once we walk you through it..
1. open configuration in virtual dj 8,
2.click on controllers and select the device to map.
3.click on the keyboard and then find the button you want to map.
4. click on it and then move the mouse over to action.
5. type in sampler play 1
now sampler will play when one is pressed now do the rest and if you get stuck I will be happy to make a video and walk you through it.
M.Stretch
M.Stretch
Posted Tue 30 Sep 14 @ 3:39 pm
