To completely bypass a problem about the inconvenience of the new beatlock location and function I have already posted, I decided to use the VDJ 7 skin until I received more feedback on my initial issue. Unfortunately, I found another problem.
The wave form in this skin is completely blocked out with the color of the deck that is selected. I have tried messing around with the settings and changing the "monochrome, infared, per-deck" settings and everything I know how.
WTH? I REAAAALLLY hope these things get sorted out by the guys upstairs. I love this program and dont want to see it take a hit because of bugs, glitches and unneeded changes.
Posted Tue 23 Sep 14 @ 12:14 pm
This is a known issue with skins on a Mac at the moment.
It will addressed in a future update.
Posted Tue 23 Sep 14 @ 12:29 pm
I've just fixed this for another user who's running a VDJ 7 skin on VDJ 8.
It's related to the change from rhythm to rhythmzone in the skin XML to display that graphic.
On Mac, using rhythm gives you a block. It needs to be changed to rhythmzone. FYI it works fine on PC using rhythm.
Posted Tue 23 Sep 14 @ 12:30 pm
