djediro wrote :
Vdj 8 is crap with all those limiters
I've tried most of the software out there - and I think VDJ8 is probably the best DJ software that has ever existed :)
Posted Tue 18 Apr 17 @ 8:45 pm
In master output mode (as used by the SX2) current builds of v8 only have the single master output limiter rather than 'all those' limiters.
Posted Wed 19 Apr 17 @ 11:12 am
i wanna kno how to use vdj 7 database with vdj 8
Posted Wed 19 Apr 17 @ 1:17 pm
The v7 database is automatically converted into v8 when you install v8 and run it for the first time
Posted Wed 19 Apr 17 @ 5:36 pm
I need mapper
Ddjsx2 vdj7 plz send me asap
Email me [email removed]
Posted Thu 07 Sep 17 @ 1:44 pm
VDJ7 does not support the SX2.
You will also need a valid licence. No-one here will send you a mapper.
Posted Thu 07 Sep 17 @ 1:56 pm
hi to all..
can anyone help me with the sx2 channels?
why i cant use the first and the third channels together or the second and forth channels together to mix?
with the first and the second ok i can manage to do it as the sampler volume fade is between them.
what about the third and forth channels how is possible to work with them?
are any settings in the vdj8 or at the controller? can i change it to first and third
and second to forth ?
note that i use the free vdj8 version to see if it works fine and after buy it.
thanks!!!
thanks!!!
Posted Thu 14 Sep 17 @ 7:12 pm
pionner ddj sx2 is capabilty on virtual dj 7.4
so plzzz send me mapping,device file
Posted Wed 03 Oct 18 @ 12:55 pm
If you want to use a DDJ-SX2 with Virtual DJ then you need to buy a license.
Posted Wed 03 Oct 18 @ 6:08 pm
