Topic: VDJ8 and M Audio Xponent Setup
I hope this isn't a repeat of a question anyone else has asked. But how do I set up the Xponent to work with VDJ8? I can't get sound to come from the on board RCA jacks of the Xponent, and as of last night VDJ will recognize the Xponent, but the controller won't do anything. Any help possible would be awesome. I am DJ'ing two parties this weekend, and need my board.
Thanks,
Robert
Posted Fri 19 Sep 14 @ 11:56 am
Are you on Windows ? Have you tried to re-install the MAudio ASIO drivers ?
Mine works fine,it detectcs the soundcard automatically and ask me to use it ,ok and go. Check the settings for automatic audio device detection and re install the asio drivers I guess The version is 6.10in the m audio support and downloads section. My only issue is that when I try to close VDJ8 it freezes and had to force it to close. Any Ideas
hmm,I guess I missed this thread (been busy with my new Asus/Alienware/nvidia 3d vision setup) but...
to close vdj8 when using the xponent and its Asio drivers just press any button after clicking "X".I'm wondering though...are you using this with 4 deck swap mapping?is it running in left/right configuration? ...anyways I just got my 3rd xponent...and in great shape...cool....
so it's plug and play?
Jeeezzz ,have'nt used mine in ages.there was a issue with the 4 deck mapping after vdj 8 second or third update.otherwise it was good...
