Topic: Crazy "backspin" sound when loading tracks....
It only last a second but occasionally I get a crazy back spin sound when manually loading a track into the player. VERY random but happens on both of my systems.
Anyone else experience such a thing?
Posted Fri 08 Aug 14 @ 5:06 pm
Anyone?
Are you using any specific MIDI controller ? Which one ?
Can you check if Backspin effect is selected/enabled on a deck or Master (MASTER center panel) ?
It was enabled. I have disabled it and will give it another try.
Many thanks!
Sadly, this did not help the problem. Same backspin effect when loading tracks. Only happens occasionally.
