Topic: numark v7 motor ON problem
when i load a song( any song ) in each deck even if its the same track and i play them both at the same time with the motor off the songs play on sync accorngly on loops etc, but if i start the motor on just one deck they cant stay syncronized at all even if you press the sync button, exept when using the pitch bend then you can put them back in sync but as soon as you let go the bend they go off beat again. if i play both decks with the motor on they are fine, i never had that problem with V7, i been having this problem since the firt build of v8
Posted Thu 07 Aug 14 @ 9:07 am
