guys trying to map hercules dj console mp3 and pitch slider going opposite way in vdj7.
Posted Mon 28 Jul 14 @ 4:00 pm
your controller is supportet natively by VirtualDJ. Achtually there should be no need to map.
what is the action you are using ?
Posted Tue 29 Jul 14 @ 2:47 am
yes but the sliders on controller are for volume and im trying to use them as pitch sliders .but when going to slow pitch it goes opposite and speeds up.
Posted Tue 29 Jul 14 @ 4:16 pm
Not tested it but try
param_invert & pitch_slider
Posted Tue 29 Jul 14 @ 4:28 pm
will do pal cheers ill let you know
Posted Sun 03 Aug 14 @ 4:56 am
did not work pitch still going opposite way to movement
Posted Sat 09 Aug 14 @ 2:53 pm
anyone
Posted Wed 13 Aug 14 @ 3:12 pm
same problem - driving me crazy!
Posted Sat 16 Aug 14 @ 10:22 am
Try to put "pitch_invert" at the place of "volume"
Posted Fri 22 Aug 14 @ 12:29 pm
tried still no joy
Posted Sat 23 Aug 14 @ 6:12 am
