Now that Yosemite (OSX 10.10) is available to Appleseed users in beta form, I can publicly post that I have been using VDJ 7.4.1 and VDJ 8 within Yosemite for the last few months without a problem.
However, I do continue to recommend that if you use VDJ 7 or 8 within Mavericks or Yosemite, disable AppNap completely or just for the VDJ 7 and 8 executable.
Posted Thu 24 Jul 14 @ 2:03 pm
I am testing Yosemite 10.10 and Virtual DJ 8 fails to open every time. DJ 7 is fine. Can this please be fixed. Warm grooves. Tom
Posted Tue 05 Aug 14 @ 3:52 am
on 10.10 Beta 5 and VDJ7 says Error under any song I put in either deck. Can't use the software at all.
Posted Sun 17 Aug 14 @ 12:51 pm
If it says "error" VDJ is not able to find the file at the given filepath.
Open the file info dialog and check the filepath.
Posted Mon 18 Aug 14 @ 7:29 am
I'm always using the latest beta along with Yosemite and have been for about a month or so at public events with zero issues. Been pretty good as of lately!!
Posted Mon 18 Aug 14 @ 11:50 am
+1
Posted Mon 18 Aug 14 @ 11:53 am
Is there an official answer to this?
I am downloading now - so I guess I will see :)
Posted Fri 17 Oct 14 @ 1:48 am
Apple has just released the final version of OS X Yosemite in it's Mac App Store, so it seems to me that A LOT of users will be upgrading their systems over the weekend. Any word on VirtualDJ 7 Pro and VirtualDJ 8 Pro being certified for Yosemite?
Posted Fri 17 Oct 14 @ 11:31 am
So far I am finding Yosemite to be more snappier than Mavericks and vdj works fine.
Posted Fri 17 Oct 14 @ 9:53 pm
Is anyone having problems with Virtual DJ 7 in the released version of Yosemite?
Posted Sat 18 Oct 14 @ 12:54 am
Majorly.
VDJ8 won't even start up for me since I upgraded to Yosemite :(
Posted Sat 18 Oct 14 @ 9:35 am
Ginger.Jesus wrote :
Majorly.
Are you using the latest beta - all your Mavericks programs should still work..
Posted Sat 18 Oct 14 @ 9:14 pm
Upgraded to Yosmite yesterday morning and have been tinkering ever since.
VDJ7 & VDJ8 work OK on my system, however, I have found a bit sluggish performance in general with Yosmite. Eventually I downloaded a memory cleaner and discovered that as my Mac only has 4Gb RAM I'm runnin out of space and constantly getting the beachball. When not running any programs I only have around 1gb of memory available!!! If I run almost any program I find that I'm left with 10-30mb of memory left (yes that's megabytes). Hence the beachball working on overtime. I have tried the SMC and PRAM reset but didn't get any improvement.
Switching to the PC side on my bootcamped Mac I found that I have nearly 3gb of memory available when sitting idle. I have used the Mac side for DJing successfully for a few weeks now, but with Yosemite being a bit of a memory hog, I am going to DJ with the PC version for the forseeable future.
Posted Sun 19 Oct 14 @ 4:14 am
Maybe try a clean install, it could be some unneeded process running. I have the same 4Gb Ram in my mac and in mavericks I was always getting beachballing. Now with yosemite, that is reduced a whole lot.
Posted Sun 19 Oct 14 @ 11:04 pm
good but nothing mistake a mixing
Posted Mon 20 Oct 14 @ 12:27 am
with which build is this happening with?
Posted Mon 20 Oct 14 @ 3:36 pm
OK, so here's the deal...After Upgrading to Yosemite and the latest version of iTunes, now VDJ does not recognizes the files in my iTunes folders. Yes, I checked the registry and the folder is there. All of my Folders and Songs are where they need to be, however, everytime I try to load it into one of the decks I get an error. I did a clean up and a fix to get rid of old files, I created a new iTunes Library to test. I also right clicked on Music to add all the files into the database once again and still get the same error. If I Browse for the file using the Volume route, I can play the file with no issues. The issue is with VDJ reading the iTunes folders. Is anyone looking for a fix to this?????
Posted Mon 20 Oct 14 @ 8:15 pm
What do you mean you checked the registry - there is no registry on a mac..
Posted Mon 20 Oct 14 @ 11:53 pm
i need more songs please for give me it.s ok 120 songs i need that songs plss
Posted Tue 21 Oct 14 @ 7:40 pm
VirtualDJ v7 is not compatible with iTunes v12 on the Mac. Your options are to upgrade your VirtualDJ to v8 or downgrade your iTunes (which may require you to reinstall/downgrade your OS) to an older version.
Posted Tue 21 Oct 14 @ 7:57 pm
