Topic: Problem with low mid high Buttons
Hello,
I have the Problem with the low mid high Buttons. They have no function.
In VirtualDJ7 everything works fine.
Posted Wed 16 Jul 14 @ 1:46 pm
On what skin?
I have new Infos about the problem.
I use an external Soundcard (Komplete Audio 6) and a VMS4 Controller only as a midi device. When the VMS4 is not connected, everything works fine. I think it is a problem with the mapping of the external midi controller.
Yes, the VMS4 is a hardware mixer - so the MIDI signal from the VMS4 to VDJ does not change the EQ in the internal software mixer, because the VMS4 is performing EQ with its own hardware. The software EQ is mapped as 'fake'.
So.....if you use another sound card to hear the output from VDJ then you will not hear the EQ change. It only changes in the VMS4 (and so from the VMS4 output).
can you tell me what I have to write in the mapping?
I have just investigated...
If you look at the VMS4 mapping you will notice an ONINIT command and an ONEXIT command. One enables all the fake mapping when the VMS4 is connected, and the other disables it again.
Just remove all the references to 'fake' from those commands.
