very nice job Juan !!!
Posted Sun 13 Jul 14 @ 8:28 am
new custom keys in the window custom
Posted Sun 13 Jul 14 @ 2:42 pm
Very good job my friend ;)
Posted Tue 15 Jul 14 @ 6:25 am
a question, why I can't do add new updates? Each time I have a white window and the date is updated but not the zip file
What is the pb?
What is the pb?
Posted Sat 19 Jul 14 @ 4:37 pm
Maybe you have reached the maximum update number ? ... kidding
The Plugin page is under re-constructions, so there might be times that the page wont work.
They are not critical updates, right ?
Btw, i ve seen you have been updating your skin constantly. Last update was last night. I dont see anything though in the description, of what the update offers and there is no version number on your skin either, so that the user knows which version he has and if he should re-download it again or not.
I ve noticed soem kind of a race lately between you, dodge and Fruit, who repeatedly trying to keep your skins on the Top of the New Arrival lists.
You all probably need to read the "when you update a skin" part of this link http://www.virtualdj.com/forums/178298/VirtualDJ_Skins/____NOTE_____to_skiners.html
Please do not reply to my post. Lets not hijack this thread. It was just a polite warning, that we are bout to take some measures in a short time to avoid things like that from happening..
If you want to reply to the above please use this link .. http://www.virtualdj.com/forums/178298/VirtualDJ_Skins/____NOTE_____to_skiners.html
Thank you
Thank you
Posted Sun 20 Jul 14 @ 1:00 am
Posted Fri 25 Jul 14 @ 10:55 am
Can't find this "side" button on your last updated version... Am I missing something ?
Posted Wed 30 Jul 14 @ 6:35 am
not upload yet, only some french users get it
Posted Wed 30 Jul 14 @ 4:31 pm
Posted Sun 31 Aug 14 @ 12:24 am
Hi jmf,
Found a bug in your skin:
greetz
greetz
Posted Sun 31 Aug 14 @ 4:07 pm
corrected
what is your resolution, to know if you have the bug on bottom?
On my resolution, 1600*900, no bugs about the white box
next update to correct the white box on bottom
Posted Sun 31 Aug 14 @ 4:29 pm
I'm working with 1600 x 900, but the screenshot I made is not full resolution. It's only a part of the skin.
The bug is in the jog wheels. It apears more and more to the end of the track(s) with full screen mode.
The other bug on the the jog wheels with the maximized mode:
Just the same as posted above.
greetz
PS: Systemconfig win7 / 64 bit
1600 x 900 resolution
V8 build 1944.784
greetz
V8 build 1944.784
Posted Sun 31 Aug 14 @ 4:38 pm
can you put a screenshot of the fullbrowser to see if you have same of me
Posted Sun 31 Aug 14 @ 5:07 pm
Okay, here it is.
The white box around is not part of the skin. I don't know why. Just ignore it. ;-)
Posted Sun 31 Aug 14 @ 5:18 pm
have you do the update?
Posted Sun 31 Aug 14 @ 5:25 pm
Just downloaded a few minutes before posting. About 11pm...
[edit]
Just dowloaded your last update. Bugs disapeared.
Thanks!
[edit]
Thanks!
Posted Sun 31 Aug 14 @ 5:29 pm
so happy to see you don't have the bug of the white box ;-)
have you test the views scratch or video in the fullbrowser (keys "+" or "-" around the key "browser")
Video is the cause of my bug so I erase it for the moment
http://www.virtualdj.com/addons/16832/jmf36000.html
Posted Sun 31 Aug 14 @ 5:48 pm
Yes, tested all modi inkluding video. No problem. Everything is fine...
Posted Mon 01 Sep 14 @ 2:34 am
Video is the cause of my bug so I erase it for the moment...
[edit] sorry, doubleposting.
Posted Mon 01 Sep 14 @ 2:35 am
FYI. the updates in the new Addons page are not automatically applied. The updates require an approval again (so its a bit different than the old Plugins page).
In other words, there might be a short delay on having the updates applied, since we need to review every single one.
btw, the recent updates of this skin have been approved just yesterday.
Posted Mon 01 Sep 14 @ 1:54 pm
