Forum: Old versions
Topic: American Audio Versadeck problem with Virtual DJ pro 7
Hello,
I'm trying to connect my American Audio Versadeck with MIDI-mode to Virtual DJ pro 7. My sound setup now is:
Input: NONE
Output: External Mixer
Soundcard: 6.1
The left deck is playing both songs and right deck is playing nothing, right side is actually dead and doing nothing... I've tried every option on the Output section but none of them is changing anything.
Also my buttons on the screen are not moving with my buttons on my deck, how can i change that?
Plz could someone help me A.S.A.P.?
Sincerely,
Joran1234
Posted Sun 06 Jul 14 @ 3:06 pm
He says press folder button for 3 seconds and go to internal menu, but if i press folder button for 3 seconds nothing happens/changes, and where is the internal menu?
OK try this info instead.
The Versadeck manual also states that both channels have to be switched to PC for it to work (both sides) as a MIDI controller.
Thank you alot, everything works fine now. U have been very helpful. :D
Sincerely,
joran1234
