After the 1870 update, the "master" sound is not only coming out of my Denon 6000, but the laptop speakers as well.
I received new prompts about using the sound card on the 6000 which I tried both options of not using it, and using it: no change.
I can adjust the sound of the laptop speakers, or mute it without affecting the master on the 6000, so I guess I'll do that for now.
P.S. Thanks for fixing the prelisten!
Posted Mon 30 Jun 14 @ 9:55 pm
Do you see any error message in the tray notification bubble when you apply the soundconfig?
Do you see this problem even if you configure the sound through the settings/audio panel, or only from the new device detected window?
Posted Tue 01 Jul 14 @ 5:43 am
never mind, we found the problem and are pushing a new build to fix it.
Posted Tue 01 Jul 14 @ 11:33 am
Thanks!
Posted Tue 01 Jul 14 @ 12:42 pm
