Hem, not sure the link will be clickable but I'll give it a try, that sounds a good idea.
But it won't tell you if a new version is out thus...
Posted Wed 30 Jul 14 @ 1:07 pm
Good point
Posted Wed 30 Jul 14 @ 1:15 pm
Therefore, link isn't clickable nor copy-able :(
But it as been suggested to atomix to verify, at least the current skin version / download new version automatically, or put a button to launch the updating process.
Thread
Thread
Posted Wed 30 Jul 14 @ 1:38 pm
I did request a new feature which informs us of updates (see here) so you can post there too if you think it's a good idea. :-)
EDIT you beat me to it!
Sorry bro ^^
Posted Wed 30 Jul 14 @ 1:44 pm
Fruit wrote :
Thx :)
So did you click on the BPM ?? ^^
Yes it works well, thank you
Posted Wed 30 Jul 14 @ 3:57 pm
Np :) sorry for the delay ^^
Posted Wed 30 Jul 14 @ 4:07 pm
Fruit wrote :
2 decks now it is an alpha version but it will become a 6 decks skin soon.
The default 4-decks skin is bundled in the package, but with darker colors according to my actual 2-decks (will improve this version too, later).
I like it, but normaly i am working with 4-decks. Would it be possible to get this skin also for 4-decks (swap from 2 to 4)?
Thomas
Posted Thu 31 Jul 14 @ 12:49 am
I will improve the 4-decks versions that you already can find in 0.4 archive, in the same manner I'm improving the 2-decks now. There will be a swap version but..., t's gonna be a surprise :)
Can't tell when it'll be ready...
Posted Thu 31 Jul 14 @ 4:58 am
Just found this..
easy to fix ?
easy to fix ?
Posted Thu 31 Jul 14 @ 1:33 pm
What the f... !
I hate fonts ><
Will be fixed in next release. At the moment,
Line 1568 :
<textzone>
<tooltip>KEY\nClick here to toggle various key infos</tooltip>
<pos x="+12" y="+8"/>
<size width="40" height="15"/>
<text size="22" color="#E1E1E1" align="center" action="get_key"/>
<text size="22" color="#E1E1E1" align="center" action="get_harmonic"/>
<text size="22" color="#E1E1E1" align="center" action="get_key_modifier"/>
<text size="12" color="#a5a5a5" align="center" format="KEY"/>
</textzone>
Try to change the height in the size tag to a greater value, let's say 22. You may have to correct the y pos too.
Whatever the windowsize I am testing the skin (as I have two screens I can stretch vdj to a 2000+ width) I never saw this issue... What is your screen rez ? Is vdj in fullscreen mode or windowed ?
Also can you paste here the content of your 'cbg' custom buttons please ?
I hate fonts ><
Line 1568 :
<textzone>
</textzone>
Posted Thu 31 Jul 14 @ 1:46 pm
Windows are nice with such "bugs". Macs dont forgive ..lol
So if you want to be sure that all textzones are displayed properly on Macs, be sure that the height follows the font size.
Posted Thu 31 Jul 14 @ 11:34 pm
I think Ill wait for the fix..just wanna play music ;-)
But the size of the bad C#m is a god size to see the keys !
Would like the keys & db bigger in the player zone aswell..
I use Windows 7 on Asus G55
1920X1080
CBG< = adjust_cbg -0.01
CBG> = adjust_cbg+0.01
1920X1080
Posted Fri 01 Aug 14 @ 1:19 am
LOL, the beauty of mystery !
Yup I should have check the xml, not only test the rendering in my screens.
Lol, as you want my friend. It shouldn't be complicated at all, anyway the next release is coming in a short time now. Again sorry for the convenience.
Cool that's what I wanted !
1920X1080
1920X1080
Thx to let me know... Unfortunately that doesn't help me ^^ I'm running windows 7 too, and I sometimes stretch the skin to this kind of size... Dunno :(
>>>>> TODO list :)
The buttons will be under the 'TAP' button near BPM. Is that correct ?
Posted Fri 01 Aug 14 @ 3:09 am
"The buttons will be under the 'TAP' button near BPM. Is that correct ?"
That would be some great extra buttons !
Posted Fri 01 Aug 14 @ 12:14 pm
Posted Fri 01 Aug 14 @ 12:19 pm
Fruit wrote :
Release this bad boy right now
Posted Sat 02 Aug 14 @ 9:50 am
LOL !
Soon, friend, soon ^^
Posted Sat 02 Aug 14 @ 12:45 pm
@Fruit
Really liking this skin.
Only 2 things missing that I would like to see added if possible.
1) Add both Remain and Elapsed together as a track time display option.
2) Not sure if you can do this in the skin or if it is a VDJ issue but it would be great if the view_options 'showmusic' and the view_options 'showvideo' buttons could change colors when activated. Messes me up everytime when I forget to switch it back.
Thanks again for the great skin.
DJ James
PS Also noticed that when a video has been played instead of a red mark through the film strip icon, it is overlaid with a music note. Sure that is fine for audio files but looks weird on the video files.
DJ James
Posted Sat 02 Aug 14 @ 1:41 pm
You can already have both three display times when enabling the 'double height' forms in the forms top left menu. Isn't it enough ? If no, where do you think those times should show ?
I can't check the icons table now I'm not at home but if possible it will be, in 0.5 :)
You're welcome :) Hope you will still use it :)
Damn ! That's weird... It looks so nice over song's icons :( Unfortunately I can't set two separate icons for this state... I'll have a new brainstorming on this.
Posted Sat 02 Aug 14 @ 2:38 pm
