lincol2 wrote :
Notice that too on one of the machine. Browser zoom expands on its own for like 13 seconds as you type in browser window and then its collapse on its own back to normal.
top left corner, make sure Device managed is not ticked
Posted Thu 07 Feb 19 @ 3:33 am
@MrDjLinton thank you that works.
Posted Thu 07 Feb 19 @ 3:42 am
I'm really enjoying this skin for Karaoke. It's not often software gets compliments from guests.
In the main VU area, I would like to display the original key, the number of 1/2 steps changed, and the resulting key. I think this can replace the filetype and bitrate. All of my karaoke files are zip and 128kbps. Maybe even separate the automix from karaoke.
I change the key with my controller. But, I could see key buttons where effects are maybe.
Posted Thu 07 Feb 19 @ 4:59 am
Perfect. Thank you. By far this is simply the best skin available from a flow and look perspective. So customizable. Now I can use it at a gig without the browser zoom jarring effect. :)
Posted Sat 09 Feb 19 @ 2:36 am
In addition to the "key" changes I put up a couple posts back, I would like a good indicator when I get an ask.the.dj request. It's real easy to miss the (x) next to the folder.
Posted Wed 13 Feb 19 @ 3:36 am
Just discoverd this skin and it;s my fav thank you
Posted Sat 16 Feb 19 @ 11:09 am
Someone heard from Fruit lately ?
I have tried to reach him.
Posted Tue 19 Feb 19 @ 7:41 pm
he mentioned a while back he'll be away for sometime, didn't say why or when he'll be back.
Posted Tue 19 Feb 19 @ 10:42 pm
Hope he is well.
Posted Wed 20 Feb 19 @ 1:27 am
LONG LIVE FRUIT!
Posted Wed 20 Feb 19 @ 2:08 am
Is it possible that you can colour the "cue" Points? In the wave form you can see the colour but not on the cue´s in the skin.
Posted Mon 25 Feb 19 @ 5:25 pm
You mean like this?
Posted Mon 25 Feb 19 @ 6:05 pm
Yes exactly! I was blind!!! Thank you very much!
Posted Wed 27 Feb 19 @ 4:34 pm
Hey,
I got a new problem that I would like some help with on this skin.
It´s the new function of toggle between musical and harmonic in the key field (the browser) on the original skin.
This is easy to toggle when pushing key on the player "keydisplay" and the browser field "key" will change.
Original skin works great: https://youtu.be/kyoZCs9LVcU
I am no master on XML and have tried to change this behaviour on Fruit´s skin, but does not working for me.
Anyone who have more knowledge who would like to help me out ?!!
(I have tried to reach out to Fruit him self, but he haven´t respond on my mail).
discussions from other topic: https://www.virtualdj.com/forums/228097/General_Discussion/Elimination_of_Harmonic_Field.html
Posted Wed 20 Mar 19 @ 3:30 pm
Now it works better, but I can not make it work from the player window :(
https://youtu.be/YyVCmqfWvH8
In XML:
<textzone name="keyleft" action="setting 'keyDisplay'">
<pos x="+10" y="+6"/>
<size width="44" height="25"/>
<text size="22" color="#d1d2d3" align="center" weight="bold" action="get_key"/>
</textzone>
On custom button:
In XML:
</textzone>
On custom button:
Posted Thu 21 Mar 19 @ 6:52 pm
New vdj update has disabled needle drop when using this skin. Need a fruit update to fix asap.
Posted Sun 28 Apr 19 @ 9:40 am
Still works OK in Controller, Jukebox and Automix views...
Posted Sun 28 Apr 19 @ 9:57 am
I think he means when using a mouse on the FRUiT skin
Posted Sun 28 Apr 19 @ 10:30 am
Yes, that's what I'm doing.
I just discovered that it doesn't work on my 64 bit desktop PC but does work on my 32 bit laptop.
Posted Sun 28 Apr 19 @ 10:51 am
My laptop is 64bit. And i am using a controller. Can't needle drop with controller or mouse.
Posted Mon 29 Apr 19 @ 12:29 am
