Thx guys, you rock ! I wouldn't have said better.
Posted Tue 23 May 17 @ 6:04 am
Hey, Dunno why I didn't find this earlier, but it's an awesome skin with all the features default is lacking. I love the way it can be customized.
Now I have a question: By the near end of a Track the time starts to flash. Can that be changed so the waveform starts to flash like it is on other software?
That would be extremely helpful to me.
Thanks in advance
Thanks in advance
Posted Tue 18 Jul 17 @ 11:33 am
ohshit wrote :
In the interim you can try, "smart_play " on Fruit skin smart button... not sure if this is what you are looking for...
DJSoulman wrote :
could have some sort of indicator to show smart_play is enabled. Cheers
Les
Les
No, that's not what I'm looking for. It's a visual indicator as in the default skin that shows smart_play is engaged or not. I have custom programmed a button combination to switch smart_play on/off. But, looking at the skin there's no indication of the state of smart_play, is it on or off?
Posted Wed 19 Jul 17 @ 1:14 am
If this could be done, this is on my wishlist for sure ;-)
Posted Mon 07 Aug 17 @ 3:35 pm
You could probably do it with a semi-transparent visual that sits over the top of the waveform and flashes. Or flash the waveform background.
Hmmm....... it might be possible to "flash" the waveform by switching it back & forth between two colours.
Posted Mon 07 Aug 17 @ 4:57 pm
or one color and transparent/invisible?
Posted Wed 09 Aug 17 @ 4:20 pm
Flash red ?
Posted Tue 22 Aug 17 @ 8:29 am
Fruit wrote :
Flash red ?
Red would be perfect, like your battery running low type thing (which is a brilliant implementation on your part FRUiT :) thank you for that )
Posted Tue 22 Aug 17 @ 8:57 am
DJSoulman wrote :
[quote=ohshit][quote=DJSoulman]there's no indication of the state of smart_play, is it on or off?
There it is. Dunno if it can fit your needs.
Posted Tue 22 Aug 17 @ 9:25 am
Fruit wrote :
Flash red ?
Haha thx !
Ok >> todo.
Posted Tue 22 Aug 17 @ 10:51 am
could it be flashing just with the color we have setup in the player?
No need for changing the colors just for flashing.
Posted Tue 22 Aug 17 @ 12:39 pm
FRUiT, could you please add to your to do list, the option to change colors to the
Focus .....(Songs list) on your skin?
This would greatly help the poorly sighted.
Posted Tue 22 Aug 17 @ 1:49 pm
Well make it an option would add too much browsers I believe. Each setup is a brand new browser w/ diff options.
I will probably lighten it a bit, not much more.
Can't you use the Browser Tweak app by DjDad for this ?
Posted Tue 22 Aug 17 @ 2:23 pm
If it stays on screen while active that indeed would work for me, thanks. :-)
Posted Tue 22 Aug 17 @ 2:54 pm
This feature is already existing,
Click the little menu icon on the left of the gain value.
Posted Tue 22 Aug 17 @ 3:01 pm
Don't have a menu icon on the left of the gain value.
There's a menu to the right of the SYNC button where smart_play can be enabled/disabled, but, it does not show anything on the skin to indicate it's current state.
I'm on a Mac btw.
I'm on a Mac btw.
Posted Tue 22 Aug 17 @ 3:23 pm
I mean this :
Make sure you got the very last version from this site pls :)
Posted Tue 22 Aug 17 @ 3:38 pm
My apologies to you Fruit! I have never noticed that menu before in all the times I've messed with your skin.
That's excellent, I have 5 weddings this weekend (Bank Holiday in the UK) and look forward to using your skin 'live' at last.
Once again, thanks for your forward thinking when you created this skin.
You've just made my day. :-)
Cheers
Les
Cheers
Les
Posted Tue 22 Aug 17 @ 3:44 pm
Sorry for the late man I thought you were aware of this, but, reading your last words, I got a doubt.
Posted Tue 22 Aug 17 @ 5:20 pm
I tried Browser Tweak app by DjDad but got an error message.
ohshit wrote :
I get a error message when I try to add color on Fruit skin, but the default skin works ok as pic .. [IMAGE1][IMAGE2]
This tweek only works with the default skin?
Thank you FRUiT.
Posted Tue 22 Aug 17 @ 5:25 pm
