Looks great Fruit. Are the POI numbers available yet and if so how do you activate that feature?
DJ James
DJ James
Posted Wed 01 Oct 14 @ 9:25 am
Deck menu / songpos / cues
You have to enter the same menu several times to get all the widgets you see in the screenshot.
Posted Wed 01 Oct 14 @ 11:06 am
Posted Fri 03 Oct 14 @ 12:53 pm
This skin really whips Dalai Lama's a$$
Posted Fri 03 Oct 14 @ 1:20 pm
Fruit, your skin is simply amazing. Thank you for all the hard work!
(makes Serato look even more crap now)
Keith
Keith
Posted Fri 03 Oct 14 @ 2:02 pm
P.S. I use a Lenovo Yoga 2 hybrid, how do you stop the browser going in to tablet mode?
When I change the computer to tablet mode the browser automatically changes to the large one .... I just want it to stay the same if possible?
Keith
Keith
Posted Fri 03 Oct 14 @ 10:58 pm
Look for the string touchscreenmode="true" at the very top of tablet.xml (within the FRUiT skin).
Either delete it or change it to "false".
Posted Sat 04 Oct 14 @ 5:02 am
I'll mod it for the next version :)
Posted Sat 04 Oct 14 @ 5:21 am
Fruit, would it be possible to add something? Can you make it when you click on the % in the pitch area it changes the pitch range?
Thanks again for a great skin
Posted Sat 04 Oct 14 @ 2:15 pm
You can already change the pitch range by clicking on the virtual dj logo (top right) and also in the decks option menu near the transport buttons, isn't that enough ?
Do you mean the little blue/red number on the deck's screen ? Or under the pitch slider ?
Posted Sat 04 Oct 14 @ 2:23 pm
I waa hoping the number below the the pitch slider that shows the actual percentage of range could be clicked on to increase the amount
Posted Sat 04 Oct 14 @ 10:38 pm
I removed the menu below the pitch slider because the pitch range is affecting both decks at once as a overall setting so I used to find it confusing to be there, but I'll put this back.
Posted Sun 05 Oct 14 @ 10:10 am
I just love what you have done with this skin and hope that you continue to pimp it.
One question;
can i stop the text on the effects button from moving backwards and forwards somehow?
Fruit, may your skins ripen and the sun always shine on you!
One question;
Posted Sun 05 Oct 14 @ 5:19 pm
Of ourse but that will require xml editing.
Line ~3235 :
<button action="effect_active" rightclick="temporary">
<pos x="+0" y="+0"/>
<size width="50" height="28"/>
<on x="8" y="1328"/>
<off x="8" y="1264"/>
<over x="8" y="1296"/>
<text dx="0" dy="0" width="172" size="16" color="#ffffff" align="center" action="get effect_name" scroll="yes"/>
</button>
Change the value of 'scroll' property in the <text/> tag from 'yes' to 'no'.
This button is to edit in several other defines (below the line 3235) :
- <define class="fx_dropdown_master" visibility="75%">
- <define class="fx_dropdown_master_smaller" visibility="75%">
- <define class="loop_dropdown" classdeck="left" visibility="75%">
- <define class="loop_dropdown" classdeck="right" visibility="75%">
- <define class="fx_dropdown_verysmall" classdeck="left" visibility="75%">
- <define class="fx_dropdown_verysmall" classdeck="right" visibility="75%">
- <define class="masterfx_dropdown" visibility="75%">
Line ~3235 :
</button>
Posted Sun 05 Oct 14 @ 6:45 pm
Thanks for your answer FRUiT.... I have to admit that that is too complicated for me to do by myself but I'll let my "I.T." guy do it the next time that I see him.
Best wishes
Ray
Best wishes
Ray
Posted Mon 06 Oct 14 @ 4:18 pm
I managed to stop the FX scrolling last night. Took less than 5 minutes.
Keith
Keith
Posted Tue 07 Oct 14 @ 2:01 am
Hi Fruit!
What about the update from 0.6 to 1.0? I cant see any differences between the two versions
(Update: Tue 07 Oct 14 @ 12:13 pm)
Greetz
Greetz
Posted Tue 07 Oct 14 @ 6:16 am
I think Atomix staff have been messing around!
The original link to the skin no longer works. The download count has been wiped.
Posted Tue 07 Oct 14 @ 6:42 am
Okay. Thanks.
Posted Tue 07 Oct 14 @ 6:56 am
They did not mess up ^^ I asked them to renew the addon because I was having renaming issues.
However the version number is wrong you're right, actual version is 0.6.
Posted Tue 07 Oct 14 @ 7:26 am
