I want to use the soundeffects "Voxengo SpanPlus" & "Voxengo Marvel Go", but I can't open the VST plugins. Are these soundeffects really incompatible with VDJ 8 or what have I to do to use these soundeffects? For these effects I only have place a dll file into the soundeffects of VDJ 8. Is there something missing to use these soundeffects in VDJ 8?
Posted Fri 20 Jun 14 @ 3:04 am
Not a V8 Bug
Both work for me, install from the exe and move the dll to sound effects.
, are you using 32 bit are you using the correct o/s type?
Posted Fri 20 Jun 14 @ 4:43 am
Locodog,
I'm using the 64bit version at Windows 8 update 64bit. I have some other VST plugins place into Soundeffects and these work good. Only the VST plugins from Voxengo don't work at this moment. I don't know why these plugins don't work for me.
Posted Fri 20 Jun 14 @ 5:36 am
Locodog,
The problem is solved. I have to use 32bit. Thank you for helpin' me
Posted Fri 20 Jun 14 @ 5:47 am
No worries
Une facture est dans le poste. :-)
Posted Fri 20 Jun 14 @ 6:16 am
