hello i want to be able to use waveform left inverted and right normal on 2 deck vdj8 please you make this possible on the default skin.
also on 4 deck version i use deck a and d to get the wavform that i like as mentioned above.
when i try and load a track to c or d with the button on my controller it goes to a and b,which is very annoying as it doesnt do it on vdj7
thanks
thanks
Posted Tue 17 Jun 14 @ 4:23 am
