Thanks RobRoy .
Thanks Jakouski.
Thanks Jakouski.
Posted Thu 05 Jun 14 @ 11:33 pm
Hate to say but I'm still not getting the 1828 version.
![](/image/31390/138437/Screen Shot 2014-06-06 at 12.45.25 PM.png)
Posted Fri 06 Jun 14 @ 11:47 am
1828 is currently in Beta.
If you have beta builds selected in advanced config of VDJ then you should get it. Otherwise you won't.
Posted Fri 06 Jun 14 @ 11:55 am
Any way to find out what is been tested in 1828, obviously other than being able to download it.
Posted Fri 06 Jun 14 @ 12:26 pm
Yes, if you have betabuilds enabled:
http://www.virtualdj.com/forums/76/Beta_Builds_Regression_Bugs.html
Please note that the topics in that forum are to be used *only* to report regression bugs - things that worked in earlier builds on 8 that don't in that build.
Posted Fri 06 Jun 14 @ 12:29 pm
Haha, (Sorry, you don't have the necessary accreditations to view this page.) I'm still a leper, no worries...
edit, (19:53) realised after I got called away I'd need to enable access, I'm such a dumb smuck!
Posted Fri 06 Jun 14 @ 1:01 pm
I have had beta builds enabled since last week (or earlier) and nothing has changed with me getting any beta builds. I have access to the regression testing thread but no S/W to test,
![](/image/56844/138446/Screen Shot 2014-06-06 at 2.34.25 PM.png)
![](/image/11138/138447/Screen Shot 2014-06-06 at 2.37.14 PM.png)
Posted Fri 06 Jun 14 @ 1:41 pm
.... I'm such a dumb smuck!
And now he realizes it....:>
Posted Fri 06 Jun 14 @ 4:38 pm
