Topic: Wave Graphics and Sound Sync Problem
I have slight discrepancy in with the synchronization of the graphic peak with the sound. Using the exact same song and starting at the exact same time (using sync). Verifying that the peaks of the grid are lined up, I need to nudge the right deck slightly to get the sounds to synchronize perfectly. When the graphics are perfectly aligned the sounds are a few ms out of sync. Anyone else with the same problem? This has been tested with/without a controller.
MAC OSX 10.9.3 on Macbook Pro
Otto
Posted Wed 04 Jun 14 @ 2:53 pm
Yes I have the same problem it is off a little... Can anyone else chime in on this...
Posted Thu 05 Jun 14 @ 6:17 am
vjmundyPRO InfinityMember since 2014
Seem I felt that. I will test it
Posted Thu 05 Jun 14 @ 8:33 am
