Topic: Builds History - Page: 1
Build 1810
-Fix some more drawText crashes on mac
-Allow multiple decks to be output on a single channel
-Fix pop sound on cue
-Fix possible automix crash when video closed or reset
-Automix updates gain before mixing
-Fix slider draw crash in some skins when no external effects available
-Fix crash on some cameras on windows
-Fixes audio dropouts when changing samplebanks, probably other audio/video dropouts too
-Fix some possible crashes
Build 1814 (05/27/2014)
-Fix batch-analyze sometimes giving wrong bpm results
-logUnsuccessful searches works with CU disabled
-Fix renaming of virtual folders
-Files scanned in order when added to automix
Build 1819 (05/29/2014)
-Fixes some videotransition plugins (mac)
-YUY2 support for Camera plugin (windows)
-Fixes Virtual Folders not stored some times
-Fix line endings on search log (windows)
-Fix renaming mp3+cdg files
-Fix SongPos shadow on high-dpi screens
-Fix possible skin panel crash
-Read track number from certain m4a files
-Fixes text display on Denon controllers (mac)
Build 1820 (Windows Only) (05/30/2014)
- fix regression bug on camera plugin (windows)
Build 1828 (06/04/2014)
-Video fps shown in cpu usage tooltip
-Deck video previews show visualisations too
-Default Pitch bend sensitivity lowered
-Remix field searchable
-Improve midi detection (mac)
-Camera plugin improvements (pc)
-Sample volume and singer column selectable with touch screen
-Fix delete confirmation on Virtual Folders
-Fix colorize video effect
-Fix bug reading Traktor cue points from tag
-Fix lock-up when resizing skin with sampler opened
-Fix crash resizing sample editor with video
-Fix crash loading certain custom skins
-Fix some bugs on the tablet skin
-Fix issue with multi-screen (mac)
-Fix crash when modifying controller mapping
-Fix images for custom definitions not working
-Controller images shown in correct size on high-dpi displays
-Chinese translation updated
Build 1834 (06/08/2014)
Fixed saving samples that are encoded in an uncompressed format
-Fix translation for root elements not working correctly
-Auto-gain still applied when fake_gain is used
-Missing folders in VirtualDJ documents folder recreated on startup
-User fields in filter folder can work both numeric and string
-resetKeyOnLoad option added
-New v8 'Text' video effect
-Sample editor mouse cursor getting stuck on mac fix
-videoFPS config option used (should reduce cpu/gpu usage)
-Improved visibility when moving position of items in list
-Fix 'deck master fx_slider' type of actions not working correctly on controllers
-Some missing translations added
-Fixed storing of order when playlist opened in sideview
-Fixed negative time display
-Fixed crash when doing fast scratch on loop boundaries
-Selecting the same effect in 2 slots will always load the same instance now
-Some small scratch wave optimizations
-Fix analyzer marking karaoke songs as regular music files
-Small rhythm wave performance improvement
-Fix possible crash reading corrupt mp4 tag
-Don't enumerate ._ mac metadata files
-Fix possible automix glitches with pitchQuality 2
Build 1845 (06/23/2014)
-Fix relative playlist paths not working on mac
-Some improvement for SCS.1d pitch stability
-Improve loading plugin ini file performance
-Fix VST plugin GUI broken after closing with windows X button
-Fix video window not responding when video initialized from controller
-Improve reading character encoding from text files
-Copy and move folders fixed
-Some skin fixes
-automixAutoRemovePlayed option also removes from automix when played manually
-Fix HomeFolder when it could have a back-slash at the end
-Fix memory leak in sample editor
-Filter effect added (for use on controllers with effect selection/knobs but no dedicated filter knob)
-Database cleanup removes missing file flag for files that exist
-Brightness parameter added to colorize effect
-Fixed sinc filter bug causing scratch with pitchQuality 2 being too loud
-Improve vid/pid detection for audio on mac
-Fixed selecting plugins using sliders
-Fixed video samples not properly released when video engine restarts
-Optimized framerate on mac (using DisplayLink to exactly match monitor refresh rate or half of monitor refresh rate)
-By default, skin is now synced at half the display refresh rate
-Improved text drawing performance on mac
-<bar> midi output can accept ccmsb
-Secondary sort order
-Fix pitch problem with timecode during lead-in
-Added skin fps to cpu meter tooltip
-Skin fps now more close to configured skinFps option (decreases cpu usage)
-Fixed "Full Kill" equalizer
-Fixed ordering and renaming of virtual folders
-Text drawing performance improvement (mac)
-Fix sampler_loop +1/-1 without slot number
Build 1855 (06/30/2014)
-Fix config window constantly refreshing when some ASIO soundcards disconnected
-Ignored controllers no longer make license window pop up
-Fix auto-gain off with unanalysed songs causing gain to change
-Karaoke background music works with only 1 song in automix list
-Sample mute also hides video
-Double-click song while in automix only mixes to next song when done from within automix list
-Some pitch improvements for denon motorized platters
-Fix pitch "all" and pitch "dual" actions not working
-Fix metronome on mac
-Fix favorite folder being created when mouse moved only one pixel while clicking folder
-Fix timecode not stopping playback when moving needle past end of song
-Fixed controller's recommended skin dialog wasn't showed
-Fix v7 tracklistings not correctly copied on mac
-Fix creating new playlist not working on mac
-Fix some sort bugs causing play time to be ordered wrong, and playlists not showing in their original order
-Pitch slider allows min parameter (for fixing reloop rmp3 pitch slider)
-pitch "touchrelative' for touch sensitive pitch sliders
-Fix bug reading iTunes playlist names
-Fix some Promo Only video crashing on load
Build 1872 (07/06/2014)
-Fix writing flac cover
-Fix prelisten getting broken playing songs with samplerate smaller than output samplerate
-Logout disabled in tradeshow mode
-Device definitions can have platform definition to limit to pc or mac
-Improve default resolution selection of camera plugin
-Fix header not written for .cue file
-Fix unable to re-order automix list when loaded from virtual folder or history folder
-Fix blackouts on some systems when skin fps is 30
-sampler_volume_master added for a master volume for sampler
-Fix possible analyzer problem when analyzing files with different sample rates
-Fix direct pc-to-pc broadcasting on mac
-Fix keepSortOrder false not resetting sort orders
-Synchronized play/cue now snaps to nearest beat instead of always going before the requested position
-fill="no" parameter for note bar midi definition added
-Fixed duplicate in list of controllers when buying PLUS license
-Full Kill eq improvement
-New "device detected" popup window
-UTF8 BOM marker written for playlists (fixes playlists becoming unreadable in vdj 7)
-sampler_bank doesn't block midi thread anymore
-Fix pitch-lock when pitch range is 100%
-Fix plugins unable to send "effect_activate" in some cases
-Fix audio automix removing video output of other deck during transition
-When a soundcard is not present on launch, use the internal soundcard until the one from the config is reconnected
-Fix HID controllers hot-plug on mac
-Fix soundcard hot-plug on mac
-Improve HID scan time on mac
-Fix browser_sort action query in non-english
-Fix finding missing/moved files in virtual folders
-Fix possible lock up when pitch gets too large due to activating pitch_lock at -100%
Build 1878 (07/13/2014)
-Fix problem with microFrames on mac that can cause image of previous video being shown when newly loaded video is of lower resolution
-"set_firstbeat" action added
-Fixed motorized platters behaving strange when platter was held still
-Fix distortion effect possible glitch when turning on
-Fix possible audio glitch when restarting reverb
-Fix phaser effect possible glitch when turning on, and high cpu usage when no music playing
-Fixed "file already exist" warnings when trying to reimport history after settings.xml was deleted
-Improve performance of browsing folders with zipped karaoke files
Build 1897 (07/20/2014)
-fix crash when closing vdj with new device window still open
-Read audio cd's
-Fix set_firstbeat
-Improved midi device detection on mac
-Fix lockup when adding lots of files to automix
-Fix audio drop-out when moving files around in a big automix list while automix enabled
-Fix play_sync choosing closest beat
-German language update
-Greek language updated
-get_beat fixed when samplerate was different from 44100Hz
-Loadsecurity 'silent' added
-Ignore dash in search when copy/pasted
-Fix some keys not showing when key detection is set to electronic instead of broad range
-Option to stop showing the login window on launch if you don't want to log in
-Can record wav files
-Fix problem with non-normalized utf characters in path names on mac that prevented cdg files from being read for these files
-Fix bug where .cdg file could be erased when non-normalized utf character were in the path name on mac
-Fix flashes on secondary screen when using videoForceFullscreen and focus to vdj is lost
-Fix crash on reading audio cd
-Fix sort on file path
-Fix wav recording
-Fix pickup controller mode not working anymore for sliders on mac
-Fix param_mod
-Fix Cmd-Q on mac not triggering close protection
-Double-click close button no longer bypasses close protection
-Repeat="yes" option for midi input buttons in definitions
Posted Wed 04 Jun 14 @ 5:02 am
Build 1910 (08/11/2014)
- Fix 'Remove' option in right-click menu in playlist not always showing up
- Camera plugin remembers selected resolution
- Fix crash when sorting in some situations
- Fix midi detection for bcd-3000
- Right ctrl/alt/shift can be used independent from left in shortcuts
- Fix NetSearch broken for some files since Wednesday
- Fix possible block on exit when still opening CU files
- Hide files starting with ._ on windows
- Fix cover not always shown on cdj-2000
- Possible HS-5500 improvement
- Fix problem with autoupdate sometimes not updating correctly (Mac only)
- Improvement for motorized jog wheels holding the platter
- Fix position jumping while scratching with serato vinyl
- Possible fix for crash on playing cdg files in some cases
- Drag&Drop from Finder working on mac
- Fix empty custom_button used from a controller
- virtualfolder_add fix
- prelisten off fix
- ONEXIT/ONINIT called when switching controller mapping
- fixed translations not showing accents correctly in uppercase
- fixed using sampleSet zip files with banks and/or folders
- default 4deck skin can show 3 fx slots per deck (need a full INSTALL, autoupdate will not update the skin)
Posted Sun 10 Aug 14 @ 9:52 pm
Build 1932 (8/25/2014)
-Fix downloaded plugins name on mac
-Fix playlist filename with accents when saving from automix
-Fix click-through of custom skin menus
-ccback added for jog wheel for controllers with different cc value for forward and backward movement
-Prelisten no longer stops working when selecting a missing or broken file
-recordWaitForSound fixed
-Fix possible automix crash when playing video
-Fix playlist copy to/move to context menu options
-Fix v7 import of Virtual Folders with certain characters in the name (*,?,/,etc)
-Fix cdj900/2000 jog display glitch
-Improve use of some icons for cdj900/2000
-MP4 recording uses AAC for audio instead of mp3 (fixes playback on mac in iTunes/Quicktime)
-Don't automatically load songs on invisible decks
-Fixed artwork covers when using linein
-Fix context menus on mac
-Depth buffer available on windows (for video effects)
-Aftertouch midi message handled for sliders
-Fix slow waveform/cover update of Pioneer CDJ's on mac causing player to stop responding for a while when browsing or loading a track
-Fix first couple of milliseconds at start of some mp3 files being cut off
-Fix pitch_zero "center" when pitch is not yet picked up by controller when takeovermode on pick up
-Font Size and Text Position options added to Text plugin
-Fix context menu not disappearing after opening sub-menu
-Reload tags fixed
-Small improvement to midi detection on mac
-Fix rename of sample set
-Shuffle Once option added for automix list
- new "vdj7" algorithm for motorized platters (in config/options/advanced/controllers)
- fix click-through in skin context menu
-Fix crackling sound in some cases when latency was configured manually
-fixed video samples in sampleSets zips
-fixed loading images from sampleSets zips
-optimized showZipKaraoke not to reopen all zip files every times
-Custom context menu resizes on expand/collaps of sub-menus
-Improve path storage in playlists
-Automix fix when using mixNow when playlist was finished
-Possible database corruption fix
Posted Sun 24 Aug 14 @ 6:08 pm
Build 1949 (09/07/14)
- new timecode engine
- adjustable settings in config->options->timecode
- faster LED refresh on MIDI/HID controllers
- improvements on the motorized jogwheels engine
Posted Sun 07 Sep 14 @ 8:18 am
Build 1960 (09/21/2014)
- fix timecode drift in relative mode
- can adjust timecode pitch parameters in options
- fix playing files longer than 26 hours
- Fix automix noise with pitchQuality 2
- Fix ramp up/ramp down in combination with motorized jogWheel
- crossfader_disable action added
- autoMixBeatmatchOnFade made optional
- autoMix time remaining more accurate
- new timecodePitchDelay option
Posted Mon 22 Sep 14 @ 7:59 am
Build 2003 (10/12/2014)
- fix timecode absolute mode
- Fix mixNow not working when automix editor was used
- Fix automix editor size cursor not resetting to default cursor
- Fix load security window popping up twice on exit
- Fix file parsing bug
- Improve playing deck selection for external mixers with video crossfader
- Fix videoAudioOnlyVisualisation when the effect was already active on a deck
- Fix automix editor playback pointer after re-opening
- Exit sysex messages send after turning off leds
- Don't overwrite stored audio config automatically on apply
- Only one custom button editor per button can be opened
- Video effects can be activated from controller, even when video engine not opened yet
- faster search on large databases
- fixed song loading when loaded out of order
- prevent creating hotcues past end of song
- fixed some rare crashes
- re-analyze removes corrupted flag if file is not corrupted anymore
- improved timecode engine
- new timecode config interface, with automatic calibration
- new algorithm for timecode pitch slider (with or without option timecodePitchSliderIgnoreBend)
- changed timecode smart mode needle-drop behavior
- vibration threshold for hid jogspeed
- fixed some potential random crashes
- better search in database when using accents and/or greek/russian/hebrew alphabet
- allow sampler_pad 1 "4x2x2" for skins that need a specific pad layout
- fix possible crash when analysing corrupt files
- Fix mp3 seek bug
- Fix not being able to set cue points before the start of the song
- Fix video mixing with autoMixDualDeck
- Fix videoAudioOnlyVisualisation sometimes activated for a very short time when loading a new video
- fix high cpu usage when using 2 pioneer controllers with same mapping
- Fix reverse on motorwheel controllers not being instant
- Fix drag files from Finder on mac with retina screen
- Fix loop_select having same range as loop_half and loop_double and not rolling over for endless encoders
- Fix iTunes database problem with recent iTunes update
- Fix 'other' plugins not correctly loaded when put in AutoStart
- loops use local bpm
- fixed glitch at end of drop samples
- Fixed possible crash callibrating unrecognized or mixvibes timecode
- fix crashing bug in Stanton's libhs1394
- timecodeAntiSkip can specify the sensitivity
- fixed timecode problems when pitch>+-20%
Posted Sun 12 Oct 14 @ 4:29 pm
Build 2028 (11/02/2014)
-Fix loops on variable bpm songs
-BPM display updated on variable bpm songs based on position
-fix potential crash in skins with mouseMask
-updateHotCueOnCueCombo option to disable cue+hotcue overwrite behavior
-Video Sampler drawn on top of visualisations, but still before other video effects
-Fix import iTunes ratings not working for some files on mac
-When multiple sound card definitions exists with the same vid/pid, prefer the one for which the hid/midi controller is also detected
-Fix automix editor prelisten not stopping
-Fix automix editor prelisten reading out of bounds sometimes causing glitches during mixes
-Improve scratch latency for pioneer ddj-sz
-Fix slicer when using multiple buttons simultaneously
-Audio only visualisation can be accessed through slot name "audioonlyvisualisation"
-Fix bug with audio only visualisation being loaded multiple times causing it to use all cpu
-Fix prelisten player not stopping when closing editors
-Fix compatibility with new iTunes libraries
-Lowered minimum level for timecode (to work with serato soundcards)
-Show calibration when selecting timecode for first time
-Fixed timecode button on audio config to use the correct soundcard
-Fix crash when trying to use 'audioonlyvisualisation' slot
-Fix automix not playing video when the same song is repeated
-Cue0 not locked by lock_cues
-Cue0 properly reset on loading a new song
-Allow dropping a sample in a specific location in list view
-Reload Tags correctly imports grouping and rating
-Fix videoVolumeLink and videoLevel broken during transitions
-Fix crash trying to play files that would decode to over 4GB
-Mac soundcard reconnect when soundcard unplugged and replugged
-Loop Roll and Slicer implemented as position plugins to reduce latency
-Fix certain actions followed by param_ actions not being executed
-Fixed bug in tablet skin causing cue button to overwrite hot cue 1
-get_decks action returns the number of decks the skin was designed for instead of number of decks active in the software
-sync action doesn't move position when track is stopped
-fix crash when updateHotCueOnCueCombo is off
-Fix bug causing some videos not to play in sampler, and take some time to start playing in the decks
-support NI controller digits
-use hidef icons in dialogs on mac with retina display
-fix audio config dropdown doesnt disapear on mac
-automatic timecode detection and calibration on first setup
-native compatibility with Rane SL2 and SL3 audio interfaces
-performance improvements for skins with lots of nested panels
Note
If the Loop Roll actions assigned to your controller do not work after this build, delete the native_Loop Roll.ini file from Documents/VirtualDJ/Plugins (or /Plugins64 for Macs) and re-launch VirtualDJ
Posted Sun 02 Nov 14 @ 3:15 pm
Build 2031 (11/16/2014)
- added compatibility with traktor timecode vinyls v2 ('mk2')
- import cue points from serato tags
- various small improvements to the timecode engine
- more choices in advanced option "getCuesFromTag" to allow import serato/traktor cues on existing database entries
- automatically compensate for badly wired needle (inverted phase) for traktor mk2 timecodes
Posted Sun 16 Nov 14 @ 6:54 pm
Build 2048 (11/24/2014)
-Fix some OS X 10.10 issues
-Fix HID color output
-Improve HID digit output
-Fix beatphase detection bug
-Fix VST plugin parameters not remembered
-sampler_mode action can work on individual samples
-sampler_loop can toggle loop on/off
-Fix activating slicer or loop roll can cause drop-out for a short time
-Fix slicer sometimes not turning on or off
-Fix slicer when used inside loop
-fix sampler_mode for specific samples
-"None" option added for videoAudioOnlyVisualisation
-Small looproll fix
-fader start doesn't trigger loading of a new song
-slicer "step" fix
-effect_select_multi "video" +1 fixed
-fix loop roll position marker sometimes not disappearing
-slicer x "pressed" action to check difference between active slice and highlighted slice
-fix beatlock unable to pause/stop deck
-fix possible glitch when slicer button released
-fix possible crash when reading corrupt id3 tag
-Fix crash with some djc actions
-Fix visual type='color' on mac
-Filter folders using 'top' are automatically sorted now
-Reverb effect parameters shown as starting from 0 instead of from center
Posted Mon 24 Nov 14 @ 6:32 am
Build 2073 (11/30/2014)
-Midi clock output (right-click on controller in config window to activate)
-fix problem reading m3u playlists exported by iTunes
-less CPU usage when using complex skins
-effect_select actions with absolute effect number
-global sampler volume also affects video
-fixed potential problem with text transparency on mac
-sampler_group_volume index starts from 1 instead of 0
-get_sampler_bank_id and get_sampler_bank_count actions added
-fix motor scratch lock when deck is cloned
-fix plugins not remembered for more than 2 decks
-video editor allows images to be overlayed
-Some high-dpi fixes for Video Editor
-Fix playback of vdjedit files in some cases
-HID relativetouchslider
-Reverb and loop roll parameters start from 0 instead of center
-Improve selection of comment tag for mp4 files
-Slideshow has option to play video
-Midi clock output setting stored in config
-Fix utf-8 titles not correctly truncated in status message
-Delete available for samples in search too
-File operations not performed on db when failed
-Fix some browser touch screen issues
-Fix sideview shortcuts with ' in their name
-Fix effect_select +1 sometimes lighting up
-Midi jog wheels that use 'inverted' note fixed
-Fix video edits with only image added not displaying as video
-Fix flickering in video editor preview
-Fix file deletion crash on Mac OS X 10.7
-Fix bug with pitchQuality 1 for looped samples
-Fix some video slideshow crash
-Fix video slideshow time to max not playing videos till the end
-fix for midi text out using sysex
-fix switching sampler from unmute trigger mode to different mode
-fix some sampler crashes
-fix sampler_rec not working when remix mode selected
-get_bpm shows local bpm
-Fix crash on windows with some midi devices sending sysex messages to unprepared buffer
-Fix scratching jumping to loop position when loop is further down the track
-Fix reading interlaced png files
-Fix track edits with just an image not opening as video
-Fix search action not focusing edit in multi-browser skins
Posted Sun 30 Nov 14 @ 12:12 pm
SBDJPRO Infinity Member since 2006
Build 2087 (12/11/2014)
-Fix crash on mac when scratching and pitchQuality set to 1
-Exists browser field can be sorted
-Group by genre filter folder recognizes multi-genre tags (separated by ;)
-Fix changing trigger mode from unmute
-Fix Slicer muting sound on first activation with on/off button
-Aiff tag reading
-Automix cut mode now uses 0.5 second fade like v7
-Fix midi clock output setting not saved correctly
-Don't start a second download when loading a CU track that is caching to a deck
-Caching a track that is already downloading doesn't block video
-Improvement for reading multiple tracks from audio cd
-Fix unicode compatibility for zip files
-Loading sample files in deck does not re-analyze them, keeping bpm and phase from sample
-Video logo position can be changed with controller license or karaoke subscription as well
-slicer 'length' and slicer 'step' usable in queries
-possible effect list crash fix
-Slicer 'length' and slicer 'step' can be used in queries
Posted Mon 15 Dec 14 @ 10:13 am
Build 2094 (01-04-2015)
-Fix drag&drop of mp3+cdg karaoke files from explorer/finder
-Aiff tag writing
-Prelisten stop on change option added to view options menu
-TouchStrip midi object added
-Fix crash when searching and corrupt utf-8 is in database
-beat_tap can now move phase by half a beat after 4 clicks
-broadcastSongInfoFormat option added
-'In Database' filter folder fix
-Actions from master plugin apply to active deck instead of master deck by default
-Fix possible Slideshow crash
-Fix beat_tap not working properly after more than 8 beats when scan engine was not initialized
-Updater relaunches virtualdj with user permissions instead of administrator (should fix drag&drop after update)
-Change log can now be scrolled through, instead of creating a dialog too big to fit the screen
-Fix midi touchstrip object
-Fix some midi objects not updated with refresh_controller
-Revert plugin actions working on 'master' instead of 'active' deck
-Fix aiff tag title/artist not stored when loaded through Reload tags
-Fix for midi sysex text
-Fix for midi touchstrip object
Posted Sun 04 Jan 15 @ 10:10 am
Build 2126 (01-26-2015)
-Improve performance of browsing big folders with cdg+mp3 karaoke files
-SSE2 audio optimizations for mac
-Fix keepSortOrder no
-Fix drag&drop from one sideview list to another
-Fix headphonesfader and auto-pfl not working together
-Fix crash when manually entering a too large deck number in controller deck selection
-Fix some speedup glitch at the end of motorscratchlocktime in some cases with motorized platters
-Fix custom sort order for top filter folders
-Fix reload tags not updating title/artist when previously read from filename
-Fix jump when disabling/re-enabling timecode in relative mode
-Fix split recording for more than 100 splits
-Add Scroll option to Text plugin
-Add Font selection to Text plugin
-variable names case insensitive
-Fix grid lines in 4 deck skin with left-right waves selected
-Fix reset sort order broken in previous build
-CU search results that arrive late are not added to current folder anymore
-Fix midi clock out speed when pitch is not at 0%
-Show login window again if log in partially failed
-Sorting by cover supported
-Fix bug with batch analyzing songs causing automix points to be placed incorrectly sometimes
-Fix .zip karaoke files showing up twice in browser on mac when zip was added to fileFormats setting
-Browser_scroll 'top' and browser_scroll 'bottom' actions added
-Midi sysex digit item added for Numark controller
-Fix deleting a sample from a samplebank in sorted list view sometimes deleting the wrong sample
-Add some extra margin when a right-aligned column is next to a left-aligned column in browser
Posted Mon 26 Jan 15 @ 3:36 pm
Build 2139 (2/2/2015)
-set_firstbeat stored in database
-fix prelisten stop on change
-numark nv browser actions
-update cover flag when reading cover from tag
-Fix selected sideview forgotten after automatic update
-Fix script variables sometimes forgotten after automatic update
-Write id3 tag to wav files
-Read/write cover from id3 tag in wav files
-Fix lead in time on serato side b
-Improved video de-interlacing
-Fix selected plugins forgotten on automatic update
-Support for older capture (directshow) capture devices
-Fix possible analyze crash
-"custom_button 1 5" syntax to select a specific variation of a custom button from scripts
-Fix rhythm wave cut off at end in some cases
-Fix cloud folder listing items double when drag&drop
-Prefer nameless comments in id3 tags
-Crossfader_hamster also applies to video
-Fix green lines at right side of some older videos
-mute action added
-Fix causing crash reading some id3 comment tags
-Added param_contains action
-param_multiply can now take an action as parameter
-Some updates to default skin (high-dpi text improvement, eq_kill display)
Posted Sun 01 Feb 15 @ 4:50 pm
Build 2162 (3/9/2015)
-Fix Netsearch video
-Fix crash trying to disable audio only visualisation from plugin interface
-Fix potential crash decoding videos
- Other and AutoStart plugins now loaded if user logs in after startup
- Only allow one load point to be set in POI editor
- param_contains fixed
- bug with some param_multipliers being executed twice fixed
- right-click on sideview shortcuts to remove a specific shortcut
- fix slicer multiple button presses
- fix some mp4 tag writing/reading bugs
- Fix regression crash on reading tags from some mp4 files
- visibility used for drop zones
- fix cue marker colors in scratch waves
- vertical scratch wave shows cue markers
- Fix ignore controller not remembered for generic midi devices
- visibility working for scratch skin object
- Fix some problems when using slicer actions with Slicer not selected in a slot
- defaultmapper parameter added to controller definition
- karaoke_add and edit_singer actions added
- fix %Pcamelot to change as pitch changes
-Export option for playlists added to copy files all the files in the playlist
-Sampler output deck stored in config
-Sampler option added to apply deck effects to sampler output
-Slip disabled on loading new track
-Scratch wave default cue marker color made more clear
-Fix touch-screen difficulty to select multiple files using ctrl or shift
-Fix sidelist/automix getting cleared when updating
-Fix midi reconnection issue that could cause controller leds to stop working
-Year now stored when saving mp4 tags
-fix shatter transition block size setting whilst not selected
-fix skin <window> element opening behind main VDJ interface on Windows
-improve support for older capture cards in camera plugin
-Fix sampler sound issue when Apply Deck Effects is active
-Fix song getting removed twice in Automix when remove played is active
-Fix effects not applied correctly when sampler apply deck effects active
-Fix metronome staying active in prelisten after closing bpm editor
-Resize and move grab zones allow for visibility
-Small sampler performance improvement
-Fix automix fade point calculation for samplerate other than 44100Hz
-browsed_file_color action to get or set the color of the track selected in the browser
-Automix list scrolls when current song is not visible in list
-Fix seeking in some videos that can only decode from start
-Added support for mask to skin cover
-resize text using param_cast 'text' x
-set action returns value so it can be used on custom slider
-sideview_title action added
-fix audio only visualisation being unloaded when trying to deactivate it
-fix screen blackout when using some combination of video effects together
Posted Mon 09 Mar 15 @ 10:07 am
Build 2174 (3/18/2015)
-Slicer 'hold' mode fix
-Fix for using multiple video effects on master with certain effect combinations
-fix regression bug caused by skin cover mask
-add 'mov' file support to slideshow plugin
-Fix edit_singer locking up video and skin while entering name
-Bitrate for vbr mp3's corrected during batch analyze
-New setting 'hotcueMode' with options for play and stutter when playback stopped
-Change hot_cue stutter mode to use stutterCue
-Fix param_multiply not working in some cases
-Fix regression bug with get_browsed_song
-Relocate function automatically reloads song on deck
-param_cast option added to format numbers with a specific number of digits
-touchwheel backspin/forwardspin not triggered at very low speeds
-browser_enter fix for moving to the next subfolder of an empty folder
-browser_options menu improved for touch screens
-fix sampler actions when specifying sample by name
-Fix crash on mac closing video window with keyboard shortcut when video window has focus
-Fix deleting files from playlist when playlist is not in original sort order
-Forward spin/backspin trigger speed increased to +-40%
-Fix regression causing loading to fail/waveforms to disappear when cloning song
-new actions repeat_start, repeat_start_instant, repeat_stop
Posted Sat 21 Mar 15 @ 8:02 pm
Build 2179 3/23/2015
-get_browsed_song "already played" can be used in queries
-reloop_exit returns true if there is a loop to be relooped
-Fix reading serato crates where parent crate doesn't have content
-fix sampler bug when using sample actions with samples identified by name
-allow relocate on multiple files
-playlist_add also works for adding files selected in sidelist to playlist
-fix focus during automix not changing just by adding files
-Fix log in window popping up twice on very first start
-More serato crate fixes
-Gemini controller browser support
-Virtual Folder fix when dragging new files from explorer
-Database copy file fix
Posted Mon 23 Mar 15 @ 4:11 am
Build 2191 (4/6/2015)
-Improved video engine
-Stutter hot_cue mode now uses last pressed hot_cue
-Improvements to repeat_stop
-repeat_start commands with same identifier now reset
-No mouse-over graphics and tooltips when using touch screen
-Fix hotcuemode play
-Backspin/forwardspin detection speed increased to +-50%
-crossfader_disable action takes effect instantly
-custom sort fields working in filter folders using group by
-Fix 'error' displayed on deck on fresh install if samplerate is not 44100
-browsed_file_color "reset" to clear the set color
-get_rotation_cue added
-mute also mutes sampler if routed through deck effects
-fix problem with slicer buttons sometimes lighting up randomly
-if crossfader is disabled, it doesn't affect video crossfader in auto mode anymore
-fix midi clock output setting not saved when no custom mapping was created in some cases
-karaoke files are never zoomed or stretched to ensure lyrics are properly readable
Posted Mon 06 Apr 15 @ 5:05 am
Build 2206 (4/21/2015)
-Mono mic works with WASAPI when automatically selected as channels 1/2
-get_level 'mic' working
-karaoke videos not zoomed/stretched anymore
-repeat_start executes NOREPEAT actions once
-Fix case sensitivity issue with group by in filter folders
-Fix midi color table
-Fix browser_scroll 'bottom' when used on folder list
-Analyze 'Desktop' limited to actual files/folders on desktop, not including 'This PC' and 'Network'
-mapped network drives can have their own database
-Fix repeat_start not usable for certain actions (such as stop, play, pause)
-zeroDb has drop-down with db values for easier access
-VU meter performance improvement
-faderStartStop option doesn't switch to different cue if deck already stopped
-Config Window stays on top on OSX
-Reset Sort Order right-click option added for folders when a order file is present
-Swap Ctrl+Drag and Shift+Drag to match Explorer (Copy, Move)
-Fix storing saved loops defined in seconds instead of beats
-'Stop on end' option added to backspin effect
-Fix parsing iTunes database with network paths
-Move/Delete file doesn't fail when file was still selected in prelisten
-Fix word wrap on action description on mac
-Fix VDJScript documentation url on mac
-Fix change log not appearing on mac
-Improved checking of moved files for Virtual Folders
Posted Tue 21 Apr 15 @ 1:15 pm
Build 2231 (05/02/2015)
-fix some broken netSearch results
-Allow scrolling in effect list drop-down with browser_scroll action
-SamplerOutputTriggerDeck option available with master/headphones audio config as well
-effect_select can scroll through effect popup if opened
-sample_color working for remix mode
-internal effects can now also be ordered in sub-folders
-Plugin subfolder with name 'ignore' will be ignored while scrolling with effect_select, or random video transition selection
-Fix effect_select regression causing effect filters not to work properly
-Fix automatic re-analyze overwriting custom bpm/phase when scan version is updated
-Fix reading certain playlists on mac
-Sort playlists listed in folders alphabetically
-Ensure zeroDb config value does not get invalid
-Improve automatic deck assignment for controllers when some controllers have been assigned manually
-Custom remix points don't get overwritten when re-analyzing
-get_slip_active action added
-Fix login using Google ID broken
- CUAudio catalog fallback to NetSearchAudio automatically
Posted Fri 01 May 15 @ 11:08 pm
54%
