Hi guys. Does anyone know how to set the slideshow to activate when playing audio files? In VDJ7 there was the option to 'Use this plugin for audio files' (or something similar) and when you set it to slideshow, you could set the folder (or the single picture) to use and then it would automatically activate when playing audio. I can't find this option in the new VDJ8 - am I missing something? I've found the slideshow option, but can't get it to automatically display when only playing audio & it doesn't deactivate when playing videos.
Posted Tue 27 May 14 @ 2:59 pm
videoAudioOnlyVisualisation in the options.
Posted Tue 27 May 14 @ 3:27 pm
Doesn't work for me - so sorry.
I selected slideshow as Option for videoAudioOnlyVisualisation but it won't start when switching from video to audioOnly... it seems as if I have to choose the Picture- Folder first...
is there a hidden command? Something like videoAudioOnlyVisualisation: slideshow?folder=D:\MySlideshow\ ???
Posted Wed 28 May 14 @ 9:18 am
You have to configure the slideshow plugin using it's GUI - you'll find it under visualisations in an effect dropdown...
Posted Wed 28 May 14 @ 2:02 pm
BTW, any option to use video clips instead pictures?
I think we can do that in VDJ 7
Thanks
Thanks
Posted Fri 27 Jun 14 @ 8:11 pm
E para colocar o SONIQUE ativo quando estiver rolando áudio, como fazer?
Posted Sat 23 Aug 14 @ 8:54 am
encontrei a solução com https://virtualdj.com/addons/16711/Milkdrop.html
Posted Sat 23 Aug 14 @ 9:09 am
