Topic: numark v7 - Page: 2
Jeffrey Tedder FTW! Hitting the second master saved me from restarting and giving up! You are my hero right now!
Hahaha Now that's funny. Glad it worked for you also. I don't know why but that simple solution works lol Enjoy!!
Heres an other solution for some problems with the v7s, start vdj8 with just one v7 on (master) then when vdj its ready turn on the second v7 on, switch the a-b decks back n forward on both v7s living in it in the normal position, (A master, B slave) and it works with 0 bugs and great latency for me.
Also just use the asio on the v7s, dont use wammi or what ever else it says on the sound card section fo the v7s. I used them on low latency with vdj7 about 4ms with no problems at all, now in vdj8 they only work better for me with vdj latency set to automatic (128) i think its 10ms.
