Hello there.
For the sampler it's more than necesary to have a full volume control when we use a external pad with sliders or knobs.
I mean, vdj is unable to keep in memory the sliders volume positions when we opening the software.
Please, do something :)
Posted Tue 13 Feb 24 @ 8:32 pm
Jesse Li Starseed wrote :
Here is a very simple wish for the sampler. Every sample has a tweakable or settable volume control level. It would REALLY be nice if the VDJ software could "remember" the volume settings you set for each sample (instead of resetting them to their default 100% level everytime I launch VDJ). It is a major pain-in-the-butt to have to spend 3 or more minutes having to reset all my samples volume levels before every radio broadcast I do, everytime I launch VDJ.
I agree, we ask this since ages.
Posted Tue 13 Feb 24 @ 8:40 pm
if you use same samples everytime you can change (and save) sample gain in sampler editor for each sample with volume 100%…..make this for all samples and volume are equlibrate 👍
Posted Fri 16 Feb 24 @ 2:04 pm
Upgrade the sampler part with quantize and Snap options, mute vocals, mute melodies and mute kick. Editing gives precise audio,
Basic beat sequencer with at least 4 options: Kick, Clap, Hat and tones, combined with stems, expanded the live creation of remixes and mashups
https://www.facebook.com/share/r/UWL6sF62F6DPKHQP/?mibextid=D5vuiz
Posted Sun 25 Feb 24 @ 2:04 am
Posted Mon 26 Feb 24 @ 9:21 am
Using the Pioneer XDJ-XZ. So you can set the Beat Loop pads to be sampler pads by hitting Shift Beat Loop button. Unless I'm missing something, the samplers get triggered, but they do not light up and blink when in use like Serato does. Is their an existing setting to make this happen, or can we update the software so that the pads light up when their is a sample in the bank?
Posted Fri 03 May 24 @ 2:34 am
DjAkuAKu wrote :
Hello there.
VDJ does remember each volume. It's just the volume/gain you set in the sample editor
The reason is that the volumes in the sample overview are for for the sample position in the bank - so shared with the next bank you load - and is supposed to be able to change with each triggering, because it's supports touch sensitive pads
So for your purpose, simply set the sample volumes on each sample in the sample editor
Posted Sun 05 May 24 @ 6:16 pm
A new sample type, for 1 shots you want to loop [bear with me hear].
I've got a load of kicks with long silent tails, I want sync loop them, but I don't want to pitch them.
Could the loop length be dynamically set at run time based on the bpm of master?
A side idea I worked on for remix skin is/was, using silent sync'd loops on the deck and that has apoi to call the one shot, it worked in principle but was a bit janky for full time use.
Posted Tue 04 Jun 24 @ 9:31 am
+1
Posted Thu 06 Jun 24 @ 4:30 pm
