Topic: Browser - Wishes & new features - Page: 6
being able to lock folders & panes (track/artist etc etc)
DJSoulman wrote :
Many of us use the automix as a "Wait list". Parking requests and/or specific tunes to play. In VDJ7 it was possible to left mouse click and drag tunes off the screen to the right side or the bottom to remove it from the list. Very quick and simple. I know a right click in VDJ8 will bring up a menu list with "remove" at the bottom, but, a left mouse click and drag is so much quicker.
The guy I work for doesn't use controllers, only the mouse with a custom skin he created himself and deck starts on an MPX mixer. He uses VDJ7 with this feature extensively and won't use VDJ8 until this feature is added.
Highlight the track and press delete on the keyboard?
Yeh, but that's a two step operation. His reasoning is that with the mouse in hand he can manoeuvre tracks very quickly by drag and drop. Removing tracks by dragging off the screen is just an extension of this. Works great on VDJ7.
Could you PLEASE add a command for the RE-ANALYZE function? So it could be mapped on a button in the skin or on a controller...
Maybe it should also work together with the deck1, deck2 etc. commands.
PLEASE!
If I'm searching in a Folder the files inside this folder will be listed first, and then the rest of my database...
The BORDER of this two "lists" is only an empty line...
Could you add an option to give a color to this line or something like a thickness?
Maybe in the <browser/>-Element of the skin...?
+1 from me on that. Another option would be to have a different coloured background for the top part of the list (which should be adjustable of course).
Also a great idea!
Maybe the contained files could be also in another textcolor as the non-contained.
On that way it should be much easier to keep the contained files in a folder visually separated from that ones that aren't in the folder.
Moderation staff wrote :
I have a long directory in the browser and when I scroll through it from my controller it would be nice if I could just keep scrolling past Z and return to A (like it works in Traktor), at present I have to scroll all the way back to the top and this is somewhat time consuming.
Greetz
Bernd
Original Post: http://www.virtualdj.com/forums/198047/Wishes_and_new_features/Verbesserungsvorschlag_in_VDJ8__.html
Maybe the new " browser_scroll 'top' " -command could help you for the moment. :)
And browser_scroll 'bottom' as well
There's always Home and End on your keyboard too!
Yes. But not Home/End buttons on controllers :P Plus you must ensure that focus is on browser ;)
And that you haven't already mapped those keys.
Can we have this bigger please. Just can't see it when gigging......got to the point I went for an eye test!
I've just been looking into some of the commands for automix (and sidelist), and noticed that some things are absent.
For example there's no way of moving a track up/down the list unless you drag it with the mouse. There no script for this, so it can be assigned to up/down buttons.
Same problem with delete. Hit keyboard delete or right click with your mouse. No script option to simply delete the highlighted track from a skin or controller button.
And no right click > select all for touchscreen users
+1 for more navigation script, delete especially
+1
Users in the German forum asked for it too.
+1 I'll go with that, More controller less keyboard (although why don't controllers have tracker balls?)
playlist_remove
playlist_move +/-
or maybe
playlist_move scroll
Because trackballs s****.... Vms had a touchpad, but that was not very responsive.
Next step, in my opinion, are touchscreens.
13%
