I have a problem with any of the skins vdj. The icons look blurry. No matter the resolution that uses the same happens. The text looks good, it's just with browser icons. Here are some pictures I took with my cell
My pc: Hp Envy Beats Edition I5
Posted Thu 22 May 14 @ 8:31 pm
I took a screenshot so that it looks better my problem
Posted Fri 23 May 14 @ 1:59 am
Do you mean the buttons like playlist/ sampler ect. at the right bottom and the browser buttons at the left...?
Same issue with all V8 Skins...?
EDIT: Ah..now i see....wicked...stay tuned...will give dan a call...
Posted Fri 23 May 14 @ 2:04 am
Is this with every skin, or just one?
If with all I seem to remember another thread that mentioned adjusting a graphics card setting.
I'll hunt it out and post the link.
Posted Fri 23 May 14 @ 2:34 am
It is with all skin even with the original skin
Posted Fri 23 May 14 @ 3:09 am
I found the topic and the solution is this.
Thanks for the help!
dj-in-norwa wrote :
go to graphic card settings, and set it to best quality (not fastest).
That should sort it
typically , something like this where you move the slider to quality
http://www.legitreviews.com/images/reviews/1169/intel_gpu_gui2.jpg
That should sort it
Posted Fri 23 May 14 @ 3:18 am
just adjust your intel graphic card setting to "quality" and you are golden ;)
move slider to right for the 3D setting
Posted Fri 23 May 14 @ 3:37 am
ah.. harrystone already posted .. ;)
Posted Fri 23 May 14 @ 3:38 am
Looks like everyone beat me to it!! lol
Did that work though?
Posted Fri 23 May 14 @ 4:14 am
It worked perfect. Thanks!
Posted Fri 23 May 14 @ 9:06 am
The solution worked perfect for me as I had similar problems, thanks
Posted Fri 23 May 14 @ 9:08 am
What's the solution with us on Mac's? We don't have an option...
Posted Fri 23 May 14 @ 9:40 am
on mac try this :
settings -> display -> resolution : best for display
Posted Fri 23 May 14 @ 10:28 am
That's the way that all of my Mac's are configured. (That option is a resolution setting, not a quality setting.) All of them have Intel 4000 or 5000 video adapters.
Posted Fri 23 May 14 @ 12:39 pm
Same problem with MBP 13'' with 1280x800 resolution
Posted Tue 19 Aug 14 @ 10:37 am
