Topic: CPU meter on virtual Dj 8 - Page: 1
My CPU meter goes to red and the song drags and skips for 5 seconds the goes back to normal. Also CPU meter goes to red when a song is uploading to a deck how do I fix.
Could he be other software downloaded onto laptop that making it slow down
Thank you
Posted Wed 21 May 14 @ 6:30 pm
Could be other software if its a resource hog.
Is it Mac or PC
System Specs?
It's a hp 2012 model
I had no problem with the virtual Dj 7.4 but I also have mixmeister installed.
I'll get the specs when I get home from work tonight
About this item
Features
AMD E Series Processor
SDRAM RAM
320GB Hard Drive
15.6-Inch Screen
Genuine Windows? 7 Home Premium 64-bit
Technical Details
Brand Name:HPDisplay Size:15.6Model:2000-416dxOperating System:Genuine Windows® 7 Home Premium 64-bit, Windows 7 Home PremiumComputer Cpu Manufacturer:AMDComputer Cpu Type:AMD E SeriesHard Disk Size:320RAM Memory Technology:SDRAMDisplay Technology:High-definition widescreen LED-backlit with BrightView technologyOptical Storage Device:DVD±RW DL/CD-RWNetworking Feature:802.11b/g/n Wifi WLAN wireless, Built-in 10/100 Ethernet LAN (RJ-45 connector)Warranty:1-year limited warranty.Graphics Ram:1973Item Package Quantity:1
Product Details
Manufacturer:hpManufacturer reference:A7A78UA#ABAProduct Dimensions:14.8 inches x 9.7 inches x 1.4 inches; 5.5 pounds
yes that is my laptop. i got rid of the norton anti virus and ill give the high performance a a try ill let you know how that goes
actually, if it is your gig machine, i recommend os + vdj...and nothing else
It's still doing it
A mac
yes...i ment not additional progs...only which came with your operating system...
chevyberetta95 wrote :
PachN wrote :
Could you download this tool and check what process might interrupt your sound output?
http://www.thesycon.de/deu/latency_check.shtml
im gonna try that now thank you ill let you know what it says
How long does it take to analyze
the DPC Latency Checker is saying:
Some device drivers on this machine behave bad and will probably
cause drop-outs in real time audio and/or video streams, to isolate
the misbehaving driver use device manager and disable/re-enable
various devices, one at at time. Try network and w-lan adapters,
Modems, internal sound devices, USB host controllers,ets.
Disables Broadcom 4313gn wifi adapter
Disabled Realtek pcle fe family controller
Disabled cyber link webcam virtual driver
Disabled hp webcam 101
CPU system is steady 49% to 55% while playing music and just standby
CPU system is steady at 80% to 93% when song is loading on a deck
Then drops back down to 49% to 55% when song is loaded on a deck
You should expect a peak when loading a file, that is not unusual.
for the CPU to be running at 50% idle, Suggests it may be time for an upgrade of a real sort out of what is on the machine.
ola gente de virtual dj como puedo trasmitir con el controlador beloopmix y no puedo trasmitir
me pueden enseñar como aserlo por favor
47%
