I would also like to request Atomix Dev. for the mappings for the Stanton SCS1d decks for the Tempo Fader+Motorized platter Speed, and Reverse MotorWheel, I have a costum button to play reverse but it has to turn off the motor (vynil_mode) or else it wont work.
platter speed and the fix for osx 10.7 analyze/high cpu issue, and I can finnally go Live with VDJ8+SCS1 system!
looking forward
thank you
looking forward
thank you
Posted Wed 26 Nov 14 @ 5:16 pm
I forgot to mention the bug scratchwave drift also still happens with pitch quality 1 or 2, does happen in 0 (zero), vinyl sticker drifts with pitch quality 0 (after a few revolutions +5); no sticker drift with pitch qua. -2
thank you
thank you
Posted Thu 27 Nov 14 @ 5:00 am
* does NOT happen in pitch qua. 0 (zero) [scratchwave drift bug]
Posted Thu 27 Nov 14 @ 9:09 am
build 2069:
analyzing tracks process takes too much CPU, causing distortion/stutter on OSX 10.7 (this does not happen on win7 or build1845 osx 10.7)
cloning decks still not fixed for motorized platters, also cloning decks does not copy cue point or loops
armed (saved) loops bug jump, not fixed;
scratchwave drift, not fixed, with pitch quality 1 or 2, does not happen in 0 (zero), vinyl sticker drifts with pitch quality 0 (after a few revolutions +5); no sticker drift with pitch qua. -2
request Atomix Dev. for the mappings for the Stanton SCS1d decks for the Tempo Fader+Motorized platter Speed, and Reverse Play MotorWheel
looking forward
thank you
looking forward
thank you
Posted Fri 28 Nov 14 @ 6:33 pm
pARtybOy³ Beatjuggling & Scratching Freestyle Pratice (first month on 2 decks)
http://www.youtube.com/watch?v=35LwHipHkVc
Posted Sat 29 Nov 14 @ 6:04 am
build 2073: "-Fix scratching jumping to loop position when loop is further down the track" thank you Atomix.
looking forward
thank you
looking forward
thank you
Posted Sun 30 Nov 14 @ 11:10 am
looking forward
thank you
looking forward
thank you
Posted Thu 04 Dec 14 @ 10:52 am
+1 on platter speed and reverse
Thanks Atomix for the great job you are doing.
Posted Fri 05 Dec 14 @ 7:50 pm
[bump]
looking forward
thank you
looking forward
thank you
Posted Tue 16 Dec 14 @ 4:38 am
new build 2090
still waiting on this,
looking forward
thank you
djdad wrote :
Posted Tue 23 Sep 14 @ 6:38 pm
For the speed (depending on the tempo), even though its just a cosmetic feature, it may be added in the near future.
looking forward
thank you
Posted Wed 17 Dec 14 @ 5:10 am
Hi,
There's no need to remind us of this feature request on every build - it may be implemented at some stage in the future.
Regards,
Scott
Regards,
Scott
Posted Wed 17 Dec 14 @ 8:51 am
sorry, its been almost 3 months since it was requested...
it's the only thing that I am missing from the SCS.1d deck mapping, platter speed and reverse.
looking forward
thank you
looking forward
thank you
Posted Wed 17 Dec 14 @ 9:39 am
It was mentioned to you at the time that it was a thing for the future though ;)
Posted Wed 17 Dec 14 @ 11:16 am
I was waiting for it has a Christmas gift! didn't got it :D
looking forward, fingers crossed!
thanks
thanks
Posted Tue 30 Dec 14 @ 4:59 am
Why would you need platter speed?
Posted Tue 30 Dec 14 @ 8:27 am
for instance beatjuggling is easier when the platters are rotating slower at -8% BPM or more
reverse Play also works but the platter must be stopped , have to use a script: "reverse & vinyl_mode"
thanks Adion
thanks Adion
Posted Tue 30 Dec 14 @ 8:46 am
vdj_pARtybOy wrote :
[bump]
looking forward
thank you
looking forward
thank you
please!please!please! I wanna master my beatjuggling!!!
looking forward
thank you
Posted Mon 12 Jan 15 @ 4:55 am
looking forward
thank you
[bump]
looking forward
thank you
looking forward
thank you
looking forward
thank you
yes, +1 on platter speed, it would add extra feeling.
Thanks
Posted Thu 15 Jan 15 @ 6:03 pm
what is "-vibration threshold for hid jogspeed" ??
if it is what I'm thinking,then the motorized platters(scs1d) also need this fix(mac/osx), when holding the platter still, sometimes I get some stutter/vibration in very small amounts.I think this would fix the slow scratch/dragging issue.
when will we have the scs1d platter speed with tempo fader update??
looking forward
thank you
looking forward
thank you
SBDJ wrote :
The vibration threshold is just that - a way of detecting and preventing small platter movements due to physical vibration. It is nothing to do with the problem you are experiencing.
when will this "vibration" (while holding the platter still) will be fixed?? I'm having these issues while beatjuggling with pauses...
thank you
Posted Sun 08 Feb 15 @ 7:07 am
[bump]
looking forward
thank you
[quote=djmicron]+1 on platter speed and reverse
looking forward
thank you
Posted Sun 08 Feb 15 @ 7:08 am
