Hey just got latest update and now can't get any sound from VDJ8.
VDJ7 still working, Sound setup hasn't changed and was working as of last build.
Will re-install and come back later this evening with results!
Posted Wed 21 May 14 @ 4:57 pm
Reinstall did not fix the issue.
First attempt i kept playlists/database and settings.
Second attempt i cleared all details.
Any help please, djing this Saturday would like to use VDJ8 but could always go back to VDJ7 if needed!
Posted Wed 21 May 14 @ 5:18 pm
use the drop down box in the middle where it saids speakers sound card u shoyld see your controller mixtrax select that as ur master
Posted Wed 21 May 14 @ 5:38 pm
correct...looks like its using the laptops soundcard...
Posted Wed 21 May 14 @ 5:44 pm
Mixtrack not connected sorry guys. Wanted sound out of laptop speakers.
Posted Wed 21 May 14 @ 5:55 pm
If you are using the laptop speakers type "exclusive" into the search bar and change exclusiveAudioAccess. You may need to relaunch or restart your computer.
Posted Wed 21 May 14 @ 6:06 pm
Dan you legend, was looking for old setting for this but couldn't find it.
manual was next choice.
Posted Wed 21 May 14 @ 6:27 pm
