Try using this application (untested) to see whether your ports are open correctly:
http://www.pcwintech.com/simple-port-tester-mac-edition
You need to be able to connect in TCP and UDP on port 8000.
Posted Sat 17 May 14 @ 11:47 pm
djtouchdan wrote :
Are you running through Parallels?
No. I just have it installed, but I completely removed it to see if that was the issue and it still crashed. I then uninstalled Soundflower to see if that could be the issue and it still crashed.
It shows a green check "8000 is online and can be reached."
Posted Sat 17 May 14 @ 11:53 pm
I'm streaming now again if u want to test it to see if it crashes. After I took all those apps out to find the root source of the issue it could be a local bug if you can connect.
Posted Sat 17 May 14 @ 11:55 pm
Still can't hear anything. If the ports open then it can't be that. Do you have another machine you could try and test from?
Posted Sun 18 May 14 @ 12:00 am
Sorry I don't. I only have this Mac.
Posted Sun 18 May 14 @ 12:01 am
If you like I can allow you to remote connect to my Mac to see what's going on?
Posted Sun 18 May 14 @ 12:02 am
More than happy too later. It's 6am here, and probably late for you.
I'll have a think about it and see whether i can come up with anything else.
Be good to find someone else with Mac and get them to test also, in case it's a Mac issue.
Posted Sun 18 May 14 @ 12:06 am
Yea definitely. I'll be up pretty late though. So contact me when you want to do the remote thing. :)
Posted Sun 18 May 14 @ 12:12 am
UPDATE! Works in Windows 7 with bootcamp on my Mac. It's definitely related to the Mac version. Plus on windows VDJ runs so much smoother and more reliable. The Mac version has a long ways to go. So many problems...
Posted Sun 18 May 14 @ 12:42 am
As soon as I get home ill help out coz I cant broadcast... I have a mac
Posted Sun 18 May 14 @ 5:12 am
Is there anyone on a Mac that has been successful in broadcasting PC-to-PC.?
Posted Sun 18 May 14 @ 7:17 am
im waiting for the MAC update to finish
Posted Sun 18 May 14 @ 9:49 am
I'm here and ready to help out :)
Posted Sun 18 May 14 @ 1:11 pm
It does look like it is a Mac issue.
Especially as you were able to broadcast in Windows (bootcamp).
Going to leave this for the developers for now and see what they can come up with!!
Posted Sun 18 May 14 @ 1:12 pm
I am having the same problem, Im trying to do the PC-TO-PC Direct from broadcast and when i try to load my own steam, it loads for like a minute, then the stream bar disappears. Is there anyway to fix this?
Posted Mon 25 Aug 14 @ 10:32 pm
Just tried this out too and and get the exact same thing as above.
Edit: Nevermind. Changing from ogg to mp3 in the broadcast settings solved it.
Posted Tue 26 Aug 14 @ 2:18 am
I'm trying to pc to pc with my friends so they can listen it won't work wtf
Posted Sun 11 Jan 15 @ 9:04 pm
Is there anyone in the UK using VDJ & has a SKY router? (The white one).
I have been paying a streaming service to stream my radio station for some years now & want to do it via my own computer.
When I used Virgin media they sent an engineer out who configured the router to do this but Sky won't help at all. (Typical)
I have no idea of what to do.
Please would anyone help?
Thanks in advance.
Thanks in advance.
Posted Sat 17 Jan 15 @ 6:14 am
Trying to Broadcast Pc-to-PC on my acer computer. But its not working, what could be wrong ?
Posted Mon 09 Feb 15 @ 6:38 pm
hello
PC-to-PC Direct doesnt work on my latop is Windows 8 with Virtual DJ 8 link: http://www.virtualdj.com/homepage/theflint/broadcast.html it doesnt play my songs :(
is this a bug? or can you give me a trial with radio server or something???
Posted Mon 06 Apr 15 @ 5:15 am
