Yesterday was my try out.
Two things went wrong.
When I loaded a song to the other deck, it automatically synced the bpm.
Strange because I didn,'t choose autoplay or something.
Also the bpm was strange. A song that was 128 bpm changed in the deck to 160 bpm, like the other song.
But it didn't sound as 160.
Second problem was that when I hit a sample, it didn't change the volume of it, after taking the volume back with my controller.
Yesterday in the afternoon when I tested it, there where no problems at all.
Tested it now:
Unmarked, smartplay, smartloop en smartcue.
Now 50 % of the loaded songs, displayed his original bpm and 50 % the bpm from the playing song !
Tested it now:
Posted Sat 17 May 14 @ 5:11 am
autoBPMMatch
Posted Sat 17 May 14 @ 8:20 am
I'm unable to stop songs from matching bpm, even after setting the autobpm to no. I use 2 decks and I can't use this software until I can find out how to stop the bpm matching between decks. I've changed all of the settings & nothing works.
Posted Sat 17 May 14 @ 9:21 am
when does it match? at track load? setting "autoBPMmatch" to no, in options, should stop that
if its not that, perhaps you have turned on "pitchlock" in the options?
Posted Sat 17 May 14 @ 9:30 am
Thanks guys for the Quick reply.
That was the problem !!!
Problem solved.
Problem solved.
Posted Sun 18 May 14 @ 5:13 am
