Billschuller wrote :
I did everything you said however it does not work. Sandbox does nothing it clicks and lights up when highlighted but does not work.
I have 2 tracks 1 song in track 1 and 1 in track 2, only track 1 playing, faded to the track playing. Next I have master plus headphones for my output, and I click sandbox nothing happens no wave appears in sandbox it doe not work. I really do appreciate your help, but I guess that feature just wont work for me...
Bill, do you have it in automix mode? Or are you referring to track 1 as Deck A, and track 2 as deck B?
Seriously, have you tried a firmware upgrade for your Ergo? See my post above for the link. It fixed it for me!
Posted Mon 19 May 14 @ 6:48 pm
unplug your usb controller setup audio for sand box it will work without your usb controller I have the same problem I gave up on using sandbox with the asio controller
Posted Fri 14 Nov 14 @ 10:50 am
I answer to this old question because maybe it might screw be useful to someone in the future .
I had the same problem with the sandbox working at random with my hercules controller ( worked sometimes and sometimes not , or is ok on deck 1 but not with the deck 2 ) but, without console ( using only pc ) worked EVER!!!!
after many tests I UNDERSTAND !!!!
when the volume fader in the play is too low sandbox don't work !! It must be at least 2/5 of the level !!!!
in fact without controller always work because by default the faders are set exactly at half volume !!!
rispondo a questa vecchia discussione perchè magari potebbe essere utile a qualcuno in futuro.
ho avuto lo stesso problema: con il mio controller hercules sandbox funzionava a random (si attivava a volte si a volte no, oppure si sul deck 1 ma non sul 2), ma senza consolle (usando solo il pc) funzionava sempre!!!!
dopo mille prove HO CAPITO!!!!
quando il volume del fader in play è troppo basso sanbox non si attiva!! deve essere almeno a 2/5 del livello!!!!
senza controller funziona sempre perchè di default i fader sono settati esattamente a metà volume!!!
ma pensa te!! sono uscito matto!! :)))
Posted Tue 03 May 16 @ 11:27 am
thank you passoborgo this is why exactly why my sandbox wasn't working, did what you said and it works, thanks again
Posted Thu 13 Apr 17 @ 4:05 am
Should Sandbox work while running my DDJ-SZ controller? If so, what are the proper config settings
Posted Fri 09 Jun 17 @ 8:40 pm
iVE GOT ALL CONFIGURED PROPERLY. AND ITS NOT WORKING.
make sure you’re in two-deck mode (it doesn’t work with four decks), make sure you actually have your gear set up so your headphones are enabled for pre-cueing, and finally, check that only one deck is currently playing “live” (it won’t work if more than one audio source is playing).
Posted Wed 04 Dec 19 @ 9:13 pm
