wasn't doing it before this last update.
was previewing track on soundcloud and opened 8 and it immediantly stopped.
closed and reopened to double check and same thing happened.
webpage will not play again until after being reloaded
Posted Fri 16 May 14 @ 6:44 pm
Sounds like a wasapisharedmode problem.
Make sure VDJ 8 has this option turned on if you're in the habit of running other software that accesses your soundcard at the same time.
Posted Fri 16 May 14 @ 7:28 pm
