I just down loaded vdj8 to my macbook and attempted to run my 2 denon 3700s with denon x600 mixer in midi mode so i won't have to use TCCD. 1st it won't let me load the 2 decks and mixer as i can with Vdj7. the only way i can get sound to come out my mixer is with setting on external mixer then sound card setting on master out on 1&2, 3&4 then the mixer operates like it should but the denons don't show the song being played then after loading a few songs on each deck the program crashes. The program is reading that i have two decks and the mixer but they don't all function like vdj7. When the program crashes it goes back to factory default loosing all my setting. Is vdj8 set up to run in midi mode without using TCCDs? If so can someone give me instructions on how i need to set it up like I do in vdj7 Thanks.
Posted Fri 16 May 14 @ 5:48 pm
The Denon S3700's are not currently working properly in v8.
Posted Fri 16 May 14 @ 6:28 pm
Thanks, ill keep using 7 until the bugs are worked out... Nice job on 8 , It's a little complicated at first with all the extra stuff but the pros know how to get to what we need.
Posted Fri 16 May 14 @ 10:44 pm
