Just got updated and saw fix cues was included. Now how? Drop the imported database and recreate or is there a special command for track basis?
Posted Fri 16 May 14 @ 5:51 am
According to the info provided on the mapping page:
shift all the cues of the song from the given amount (can be used to fix the cues from v7 imported files in case the automatic fix didn't work properly): 'shift_all_cues -10ms'
Posted Fri 16 May 14 @ 6:12 am
since the bug with the old mp3 encoder (silence at start of some tracks) in VirtualDJ 7 vs the encoder used in VirtualDJ 8, the amount to adjust is inconsistent (else we could just have applied an auto fix - and have somewhat already for the average shift, but impossible for all, as the amount can differ at some songs )
The shift action provided, is to adjust those that are still wrong, where you can shift all cues backwards for the songs where you see a drift, and have lots of cues you want to keep. This would only be needed if you have lots of cues set in the song
If you have just a cue at first beat its easier to just set a new one..
Posted Fri 16 May 14 @ 6:17 am
it sucks ! lol
Posted Fri 16 May 14 @ 6:25 am
This reminds me of the PCDJ VRM update from old Red. At this point, easier to make news ones. Just need to be mindful prior to.
Sounds like a good FYI sticky. :)
Posted Fri 16 May 14 @ 6:29 am
