seems like the the CrAcKiNg is back to haunt me.... but this time im getting constant crackings through out the entire track.
any thoughts?
any thoughts?
Posted Thu 15 May 14 @ 4:58 am
without any details about your system, specs and settings....honestly ....no....;-)
Posted Thu 15 May 14 @ 5:01 am
Posted Thu 15 May 14 @ 5:23 am
LOL
XP
asus f5 entertainment system
core 2 duo
nothing special... it was my 1st gig machine
ohhh, using cdj 400's
XP
core 2 duo
Posted Thu 15 May 14 @ 5:25 am
OK, what audio interface are you using? "External mixer" setting and the CDJs as sound cards?
Posted Thu 15 May 14 @ 5:27 am
iv just switched to 7.4 and everything running ok... im going back to V8 now... BRB
Posted Thu 15 May 14 @ 5:35 am
ext mixer and cdj 400 and 2 deck interface
Posted Thu 15 May 14 @ 5:37 am
I assume you're using the Pioneer ASIO driver. What's the buffer set to?
What are your ASIO related settings in VDJ 8?
Posted Thu 15 May 14 @ 5:39 am
ummm, wheres that in V8??
face palce
face palce
Posted Thu 15 May 14 @ 5:46 am
Where's the buffer, or where's the ASIO setting in VDJ?
Please, don't make me get my CDJ-400s out. :-)
Posted Thu 15 May 14 @ 5:53 am
If your soundcard is recognized you should see a small "Asio" labled pic in the soundsettings.
Just click on that.
Just click on that.
Posted Thu 15 May 14 @ 6:00 am
asio settings, i don't know where it is, i cant find it.
buffer is automatic
buffer is automatic
Posted Thu 15 May 14 @ 6:01 am
in card, i see
internal sound
two sound card
sterio to mono
and pioneer
internal sound
two sound card
sterio to mono
and pioneer
Posted Thu 15 May 14 @ 6:03 am
Maybe today I will try VDJ 8 on XP with my two CDJ-400s (later).
Posted Thu 15 May 14 @ 6:08 am
no rush... i just wanted to try out my xp with my djm 700 but with the music not working i cant fix my other problems that im having
Posted Thu 15 May 14 @ 6:10 am
As much love as I still see for XP, be aware guys, that the platform is no longer supported by MS, and (system) patches no longer are built. 7 should run fine on the same HW as XP without problems (especially a dedicated box for VDJ)
Posted Thu 15 May 14 @ 6:58 am
Go into config.
Tick the box to enable advanced options (top right).
In audio options turn off (set to "no") the Ultra Latency option.
Posted Thu 15 May 14 @ 3:25 pm
On my Asus lappy got same issue get static crackles and can just hear song in back ground.But i put VDJ8 on Desktop PC changed no settings works like a dream.
But i am not using a controller just going through earphone channel like i have with VDJ7.
So seems i need to fork out some cash and get me a controller now......oh happy days of dj'ing lol.
And My lappy is running on windows 7.But to save any problems with other programs slowing VDJ down i use a Gaming mode which closes programs that are not needed to use VDJ :)
Posted Thu 15 May 14 @ 5:38 pm
Have you tried enabling wasapiSharedMode in the advanced config menu?
apologies if you have - i did quickly scan the thread but couldn't see whether you have tried that.
Posted Thu 15 May 14 @ 5:40 pm
Thanks for that......Working now :) woohoo.
But still getting a controller soon.
Posted Thu 15 May 14 @ 5:56 pm
