Topic: VDJ8 Problem with Reloop rmp-3
Posted Thu 15 May 14 @ 3:12 am
We will update the mapping files to correct the pitch slider.. but in the meantime you have obviously enabled beatlock on deck 1.
You can map a custom button as .. beatlock , so that you can disable that, and then map the pitch slider as .. pitch_slider
