FOUND A BUG: It seems impossible to index on BPM then KEY like in VJ7.
Also BPM column aligns to the RIGHT, and KEY aligns to the LEFT. It makes it hard to read. VJ7 has the KEY column aligning to the RIGHT as it should.
And when you re-index the column the position select bar goes down 7/8 the way where in VJ7 it goes to the top.
I don't like searching for it. Having it at the top of the column makes for faster scrolling.
Please return to VJ7's functionality. It was logically perfect. VJ8 multi-column indexing is screwed up.
Posted Wed 14 May 14 @ 5:51 pm
