Hello I'm using Pioneer DDJ SX and fader channels do not work, only the crossfader. Greetings and thanks for the help.
Posted Wed 14 May 14 @ 3:49 pm
If you are using a custom mapper then you need to update it or use the native one. The commands for the mixer has changed in version 8.
As a quick soloution:
Go to Documents\VirtualDj\Mappers folder
Create a subfolder named "backup"
Move any "Pioneer DDJ SX ........ .XML" file in that folder
Relaunch VirtualDj 8
Posted Wed 14 May 14 @ 4:25 pm
