does VD8 use def files for custom mapping? My LEDs no longer work on my APC40
Posted Wed 14 May 14 @ 12:29 pm
webedge try this
Try this on your custom mapp add a new line at bottom of the list then go to key learn
press/turn a key that you already map you will see a new name for it highlight and copy
it. Delete the new line past the new name where it should be in the list.
This should work if your custom map shows up in the main list.
Posted Wed 14 May 14 @ 2:32 pm
sorry bro you said LEDs not working this may not help you out sorry again bro....
Posted Wed 14 May 14 @ 2:43 pm
